>The only way that I can rectify a screw-up will be to cut 1/2" off the edge of a 1/4" plate glass sheet 22" long. I've cut glass before, and have a cutter, but I am not at all sure how to ensure a clean cut of a small strip. Any suggestions?
>I worked with stained glass for 30+ years. I can tell you from experience that a 1/2" x 22" cut is extremely difficult to snap off, even with decent equipment (which you probably do not have). With that in mind...
Use a SHARP, NEW glass cutter. Tape a straight edge securely on the glass so that the straight edge will serve as a secure fence along which you will draw the glass cutter. Oil the cut line (light machine oil works fine for just this one cut, or you can even use kerosene...I used kero for 25 years working with stained glass). Just make sure you lube the line and the cutter if you have no cutting experience.
Stand so you are at the bottom of the cut, with the top farthest away from you. Press firmly (you are not crushing the glass, just scoring it) and, starting at the edge farthest from you, draw the cutter toward you to the bottom of the glass. Be careful not to run the cutter off the glass...this could cause chipping. Do NOT go over your score line again! Doing so will only create a hundred little chips that each think they are the line of breakage!
Some will tell you to grasp the cutoff section between thumb and forefingers and snap down along the edge of a table. This works well for larger cutoffs, but not for 1/2"x22 pieces. I guarantee that a piece this small will snap off partly along the score and partly at an odd angle. Instead, turn the glass score side down and, using the ball end of the cutter or some similar small round metal object, start tapping the glass along the score line. You will see a dark line appear above the score...this is the glass starting to break and follow the score. Keep tapping and moving up the score line just hard enough to watch the dark line follow the score. This is called "running," and is the easiest way to get a long narrow piece to break off without actually having a pair of running pliers.
When you are finished, you will have an edge that is just a bit ragged with glass shards. Take a smooth, round metal object (screwdriver) and rub along the edge with the sharpies sticking out (sharps should be forced down to keep them from chipping away from the surface...sort of like scraping down-grain instead of up-grain).
Or...if quality of cut is critical and the edge will not be completely covered, take the glass to a shop with the right equipment. They will cut it and remove the shards for a couple of bucks...less than a 2 minute job for them. 1/4" plate is not so easy, and the thin cutoff makes it a real hassle.
If you do it yourself, the "running" method is pretty easy, just not 100% smooth. And you might ask for some scrap glass to practice on first.
>None taken, Joe. And thank you so much for taking that time to help. I will take yoiur final advise (won't finish the project tomorrow!) and take the glass to be cut by a pro monday morning.
>I'll second the offer to take the glass to a pro. I've cut a fair amount of glass and almost always had problems with pieces that small. I don't have the proper equipment. My local glass shop does a wonderful job, it's not expensive, and greatly relieves the stress you are now having.
I did find that I have to give my glass guys dimensions with tolerances. For example If I tell them 11 x 14 it will be close to 11x14 but not dead on. If it must fit an exact dimension I till them 11x14 but absolutely can't be larger than 11 1/1/16 x 14 1/8 or smaller than xxxxxx etc. Ideally I take the piece and say make it fit this. I have had a couple of occasions where I had to spend a very long time hand sanding an edge to make it fit. It takes a long time to hand sand a 1/4" thick piece of glass to remove 1/32".
