>Is there a way to remove a used up Glaser gouge from it's handle, and then reuse the old handle? My 5/8" Glaser (red handle), is getting pretty short, and will need to be replaced within the next year, I'm guessing. If I can reuse the Glaser handle, I'd like to. Thanks!
>Heat will release the glue used to attach the Glaser tool from it's handle.
You may need to be a bit aggressive with the process so using a vise on the handle and using a pipe wrench on the tool while you apple HEAT to the joint. make sure the tool is pointing up a little so the shot doesn`t fall out.
>Molly, I have replacement steel for the old Glaser handles, Jerry made the bushing to fit the steel which is .015 oversize so any gouge won't fit in this bushing. I do have the 3/8 and 1/2 inch in stock right now but no 5/8 inch. The good thing is I'm milling over the next couple weeks and the steel you need will be done in a month.
The new to me mill is finally running... YEA! They sent out parts three times, it ended up being the mother board.
>Doug: When you get these 'Glaser replacements' done, could you let us know? I'd like to put a replacement for my 5/8" Glaser 15V "in inventory".... Thanks, Rob Wallace
