REAL MILK PAINT
bowl turning-Jimmy Clewes
paull waddle
>At the local LAW meeting,Jimmy did a masterful job turning a 16" bowl out of ambrosia maple-quite interesting. Also Easy Wood Tools demoed square shaft tools with interchageable carbide tips-they seemed to cut really fast and leave a nice finish. Also in a sort of by the way,I found out why my jet mini tool banjo wouldn't slide very easily,the lock nut was run up to far (too?). Its always nice to go to a turning meeting-never can tell what you'll pick up.pw
Re: bowl turning-Jimmy Clewes
>I bought some of the Easy Rougher tools in Nashville to try and have used the smaller one a bit but not yet the larger one. It cuts amazingly well. I haven't used it on a large bowl yet but I did rough out some spindles. Looks to me like some day half of our tools will be carbide (or ceramic - I have some samples that look promising.)
In Nashville Clewes made note of the clear chip deflector with: "Brilliant!".
paul waddle
>Yep, that chip deflector is an excellent idea... The insert carbide tools are also good ideas,metal lathes have used them for yrs-for all but interrupped cuts(that chips them).
Jimmy also stated that the curved discs(hunter type) were good for end grain cutting. He showed me one with a sorta cut limiter to prevent catches.I'm not at all familar with these, but I'm told they will catch frequently until a good understanding is gained from
practice-then they are excellent for hollow form work. Jimmy thinks the Hunter tool is the best... pw
