Have a question? Ask Woody!
Craft Supplies Live Center
Philip Morris
>Looking to upgrade the live center on my Jet 1220VS. Was planning to go with the Oneway, but saw that Craft Supplies is selling one made by Precision Machinery. It seems well made and has a number of accessory tips.
Anyone have any experience with it?
Re: Craft Supplies Live Center
I like the Nova live center
>The nova live center has a lot of accessory tips but best of all is that they fit in the live center via a short #2 morse taper. This means that it's very easy to make wooden adaptors to fit almost anything. I routinely make a wooden center of a specific size to fit in holes for lamps and tool handles.
It also comes with a center that has a screw thread. This is very easy to make cone, reverse cone, or ball centers to hold almost anything.
Since they are #2 morse tapers you can put these homemade pieces in the headstock for shapeing or even on occasion use them to drive a piece.
I've had my Nova center for about 10 years and used it a tremendous amount and I've never had to replace a bearing. I think that says a lot about the quality.
It's also hollow so you can use lamp augers with it.
About the only downside is using a knock out bar to remove it. All of my lathes have self ejecting tails stocks so this isn't a problem but the hole in the #2 morse taper shank is just a tiny bit bigger than the hole in my lathe so a knock out bar sometimes won't work. This has never been a problem because the live center has a flat back larger than the tailstock quill. I simply put my skew or other wide tool between the center and tailstock body and crank it back. This ejects it quite nicely.
I've looked around for other live centers that might be better and haven't found one more versatile.
Re: I like the Nova live center
Philip Morris
>John,
Thanks for the detailed response. I had seen another thread in which you expressed similar positive comments.
I originally included the Nova center on my list until the CS rep said that the move to Chinese manufacture had affected the quality. I'm sure with yours being older it was New Zealand made. Have you had any experience with the Chinese units?
Tom Minehan
>I have been using a Nova Live Center for about 4 yrs. I have no idea where it was manufactured but I have had no trouble with it. If the need were to arise I would buy another. I have not seen any complaints about it in the "Nova Owners" forum either.
Which Nova Live Center?
David Walser
>John,
CSUSA carries two different Nova live centers. One for $68 and the other for $100. Which one are you referring to? (The cheaper one looks like it's the better alternative -- and not because it costs less.)
Here are the requisite links: $68 version $100 version
Re: Which Nova Live Center?
Alan Trout
>I own the Chinese made live center from Nova. It is fabulous center with no troubles what so ever. I think they are one of the best values going.
Good Luck
Tom Minehan
>Looks like I have the $100 version (didn't pay that much). Checked the Technatool web site and it looks like the current product is the $68 version. The two versions look about the same to me other than the cone in the $68.
Richard Allen
Re: Craft Supplies Live Center *LINK*
Richard Allen
>CS has another live center with interchangeable tips. The tips have a short taper which helps insure that the tip is centered in the live center.
The center has a collar which uses tommy bars to unscrew and force off the tip. The threading for the collar is 3/4-16 tpi. You can get third party faceplates which are 3/4-16 tpi so you can turn any shape live center tip you like. You can also get a 3/4-16 tpi to 1-8 tpi adapter which will let you mount a turning on the tailstock so you can center the turning on a vacuum chuck.
This is not a hollow center so you can't do long hole boring with this live center. The stock Jet live center is a hollow center.
CS Live Center
GalenV in Iowa
>Can I ask a stupid question?
When you say you want to upgrade your live center I see you got suggestions but I was wondering what you were looking for in an upgrade?
You make referance to interchangable tips. Is that why?
I have had a time when I would like to have a large cone but got by. I know the Jet only has a single bearing so upgrade to two bearing unit?
Just trying to learn why people see a need to upgrade parts on lathe.
May give me a reason to buy something new!
I would like a different tool rest before another live center.
Thanks if you got a minute to say why.
Galen
Philip Morris
>Galen,
First off, the stock live center is really of pretty poor quality. The one that came with the lathe was defective. The bearing assembly would come off the morse taper everytime the live center was backed off a piece. Jet quickly sent a replacement, which wobbles and hums when engaged.
So the primary reason for me to upgrade is better quality. But since I am doing it, I wanted to go with something more heavy duty and one with the ability to change the tips.
GalenV in Iowa
>Philip
The live center bearing on my Jet 1220 lasted about a month. I called them and they sent me a new one. Before it arrived I had gone out and purchased a new bearing for the bad one. Seated the bearing in CA as it would turn in the race. Slide out like yours.
Guess I have been living with since.
I did purchase another live center but just to get the 60 degree tip for the pen mandrel. The only store around had no new point to fit the Jets live center. Should have done better shopping but then at the time I did not know what other features I may need. The large cone being one now.
Gettng smarter by reading Wood Central (Well sometimes more confused too)
Thanks for info.
Galen
