Re: Glue Block
Wally Dickerman in Arizona
>Sean, Newspaper was used many years ago to make the glue block easy to remove. It makes for a weak glue joint and that is not what you want. I've been using glue blocks on much of my pieces for a lot of years and I've always used med. CA glue. Yellow glue is just as good but of course you have drying time. I use accelerator, so the piece can be mounted on the lathe immediately after gluing the block.
I usually use glue blocks and faceplates in my beginning classes. I want the students to know that an expensive chuck is not needed to turn bowls.
There are 2 things that must be done to insure that the block is secure. You are making a glue joint, so both surfaces must be flat and true. If a glue block joint fails it's nearly always because not enough glue is used. With CA I apply enough glue to get squeezout after just using hand pressure.
I part the piece off by using a parting tool down the joint until I can pop the piece off with the heel of my hand. I've done this hundreds of times and can't recall losing one
Wally
