Finish for Cocobolo
Finish for Cocobolo
Finish for Cocobolo
Jay Sweeney
>Any suggestions? I know cocobolo is very oily, but that's the extent of my knowledge. Thanks in advance.
Re: Finish for Cocobolo
Greg Haugen
>Most people just wax/buff it. I also know of a pen turner that uses waterlox to finish his "rope twist" pens which are made out of cocobolo. It's been said that if the surface is wiped down with DNA before applying the Waterlox then there's no issues since it's "suppose to" break down the surface oil of the wood.
Greg H.
>I like Myland's friction polish for small things made from cocobolo.
I would not use oil. Once I put Watco oil on one of two otherwise identical pieces. After a year the oiled one was as black as ebony.
Al Neighbors
>I use lacquer. After sanding (and occasionaly, between the last couple of grits) I apply a Lacquer Wash, ala Carole Valentine, and buff it dry with old tee shirt material. Then I usually apply another wash, buff it dry, and then let it cure well before final buffing with EEE, WD, and Carnauba.
I have a hollowform that I did that way a few years ago, and it's still beautiful.
Carole Valentine
>Waterlox here. I don't bother with the alcohol. Sometimes I just sand really fine with micro-mesh, then wax.
Barbara Gill, Remlik VA
>I only use a penetrating oil then buff. I never have had any issues, only a nice finish.
Jay Sweeney
>Thanks all. Appreciate the info and your time!
