Paasche airbrush
Paasche airbrush
Paasche airbrush
Mike Cunningham
>Anyone using the Paasche Talon? If so, could I have your opinion please.
Thanks
Mike
Re: Paasche airbrush
Ken Oakley-Sunny St. Cloud, Fla.
>I don't have the Talon, but do have 4 Paasche airbrushes I aquired in the 1960-70's and everyone still works great. And I used them a lot.
charlie belden
>I've got, and have used, though not recently, a pair of Passche VL airbrushes, played with a few Iwata airbrushes as well as one I'd suggest you look into - Aztec airbrushes. All are double action - you get to control both the AIR and the "medium" independently
The Paasche and Iwata are earlier generation airbrushes that use a needle extending through the body which fit in a separate matched tip. The fine point on the tip of the needle is easy to ding or bend and you need to use the right "tip" for each needle. Problem is which tip is which and which needle is which is tricky. Paasche puts scribe lines around the end of the needle opposite the point - 1 line for #1, 2 lines for #2, 3 lines for #3. The semi-delicate little tips are a bit tricker to identify - and unless you have really good vision - require some magnification - and they're easy to loose - make that "misplace".
Mismatch needle and tip and your results will be - let's just call it - "less than ideal".
Both the IWATA and Paasches have the hose come of the bottom of the brush near the center of the long axis. That means that you have to change your normal pen/pencil grip to accomodate the fitting and hose sticking between your middle and ring finger and you've got a hose at 90s to the brush - and often parallel to the surface you're working on. And if that hose contacts the surface you're airbrushing . . .
The fixed top mount medium cup can be kind of a PITA because it limits how you can orient the brush to the work surface. Even with a lid on the cup, tilting the brush too far can drip medium - on you - or worse yet - the work.
The VL has a bottom mounted siphon feed cup which can be swiveled for different brush orientations- but, like the fixed top mounted gravity feed cup - can have spills or drips. Not good.
The AZTEC airbrushes are next generation brushes that appear to have been designed starting with a clean slate. As a result, IMHO, they get around the shortcoming of the earlier "old school" brushes.
How?
Metal is only used where it's actually needed - everything else is modern plastic - and there ain't no pretty, but unneeded chrome.
Rather than a separate needle and tip, the two are, along with a return spring, one assembly - which are color codedso, once you get used to which color is the finest and which is the coarsest, gets around the "where is my magnifying glass?" thing. And an assembly of the key components means it's harder to "misplace" one larger thing that two smaller ones.
And because the needle, tip and return spring are in one assembly, which is easy to remove from the body of the airbrush - you unscrew the assembly and drop it in cleaner - instead of disassembling the whole airbrush- without having parts fall out or spring come out of their holes.
The AZTECs are "side feeders" rather than top or bottom feeders. And you can mount the medium cup on EITHER side of the airbrush - AND swivel it. So you can work shooting straight down - or straight up - without having medium drip on your work, or down your arm.
The medium cups are sort of like TEFLON, not much sticks to their insides - even dry paint. Peels right off.
The hose connection on AZTEC brushes is off the BACK - so the grip is more like a normal pen/pencil grip - index finger on top to activate and control the trigger - that being the same as used for the other two brushes. With the hose at the back, it's much easier to wrap the hose - a smaller diameter plastic curly hose, around your arm where it'll stay out of the way - and off your work.
Oh, and you don't have to take the back of the body of the airbrush off to adjust the needle to tip relationship - there's a flat cylinder on the top rear third of the body of the brush that's easy to turn to adjust the spread of the medium at the tip - while you're spraying. So the AZTEC is sort of a Two and a Half Action rather than a Double Action airbrush. As a result, you can go from a very fine line to a fairly wide spray pattern quickly and easily.
OH - and the AZTEC brushes and sets come with "boxes" that have nice little easy to get to homes for everything - brush, needle and tip assemblies, little plastic "wrench", medium cups - and even the spaghettie curly hose. All fit in a nice neat little box that doesn't take up much room.
So - if you're looking into some way of spraying your pieces I strongly suggest you look into the AZTEC line of airbrushes.
I googled airbrush and AZTEC and came up with the attached link that has some decent photos and descriptions of AZTEC airbrush sets.
More than you probably wanted to know - but better too much info than not enough.
Disclaimer: I have no connection to AZTEC or any of their resellers. I own one, have used it, and like all the advantages they have over "old school" airbrushes.
Mike Cunningham
>Great info, thank you very much for taking the time to post it.
Mike
