>To cut down on the costs of heating my shop during the winter in Michigan I'd like to turn the heat way down. I've heard glues and finishes should not be allowed to freeze? Yes? No?
In the CA glue thread they talk about using a refrigerator. Would this work for other glues and finishes?
Trying to save money on heating but don't want to waste a lot more on ruined finishes and glues.
>Hide glue - pellets can (and should) be stored in the freezer before reconstituting.
Liquid hide glue should NOT be allowed to freeze - I keep mine at room temp.
Yellow glue - do not allow to freeze.
White glue - do not allow to freeze.
Epoxy - do not allow to freeze
Finishes - most of the waterborne finishes should not be allowed to freeze. Most of the solvent borne finishes don't do well either.
You can make a "warm box" by building a small box with lid. Put a shielded light fixture in the box (shield with cardboard, foil or a thin piece of wood (1/4" ply). Put a 25 or 40 watt bulb in the fixture and turn it on. See what temperature you get. Alternatively if you can find an old small refrigerator (think dorm size), you can just use that. Don't plug it in, just put your stuff in it.
>Jim In my shop freezing is not the only problem. Epoxy's and some other paints and chemicals won't flow below 50 degrees. I bought a steel cabinet from the office supply house and put 1/2" styrofoam with a silver side inside the cabinet. Then I built wooden shelves with slots to let the heat rise. I put a 60 watt light bulb in the bottom and a thermostat in the top. Then I just stuck a thermometer in the cabinet and adjusted the thermostat until it stays at 60 degrees at the top. It's usually hotter but a about 10 degrees at the bottom.
I keep all the paint 6" or more from the bulb for safety sake even though it doesn't feel that hot. It has worked great. My shop often gets down to 32 inside on really cold days. The cabinet stays around 60. The only problems I've had were bulbs burning out. I need to put in some kind of circuitry that turns a light on outside when the bulb inside burns out.
How about using two 40 watt bulbs? Chances of both burning out at the same time are pretty slim. That's what I do for baby chickens in the winter - use two brooder lamps. We lost 4 dozen chicks last winter because my friend used a single lamp and it burned out one night.
Also, if you look around you can find bulbs rated at 130 volts instead of 120. These usually last longer.
>I would try appliance bulbs. Most are 40 watt but they can take a lot of heat and cold if they are being cycled on and off by thermostat. Generally pretty long life.
The heavy duty or 130 volt bulbs on 115 or 120 may give you long life but then they are like anything, you can always get a poor bulb.
I hate it when you buy a new bulb and go home and put it in the fixture only to have it blow when turned on. This can be name brand not just generic for me.
We used Chomalox heaters in control consoles/panels and you can get one that screws into a porcelin lamp base, they last but cost more than a bulb.
Probably safer with metal case that would not break like glass bulb if fumes in cabinet
>Twenty years ago I got some highway traffic signal lamps that were designed to be inefficient, but long lasting. They worked great in my warming ovens.
