Grinder wheel hardness ?
Jim Stoppleworth
>I have an 8" slow speed grinder. I'm looking to replace the existing wheels with new ones at 46 and 80 grit. What hardness is best for turniing tools (all HSS except for one crowm PM gouge.)? And are those the best grits?
Re: Grinder wheel hardness ?
>I think that is a good choice of grits. If my memory serves me I think the hardness is a J or K.
Rick Allen
>Depends on the tools you are sharpening. Those grits are good for larger tools like 5/8" bowl gouges. They are a bit coarse for 1/4" spindle gouges. 60 and 100(or 120) would be good. Use the 60 for larger tools and the 100 for smaller tools.
Greg Haugen
>Jim,
46 and 80 grit, you must be looking at the Norton 3X tools. Those are a good set. I know bowl turners and spindle turners that use them. It's all in the "light touch" of the steel to the wheel and a properly dressed wheel.
For turning tools you're best off with J or K. They do have "I" in the norton 3X but they're a bit too soft. You'll be dressing the wheel alot to get the grooves out, hence the wheel will be "consumed" faster. So stay with the J or K hardness of any wheel.
Greg H.
>Jim, I asked Doug Thompson about this once. He uses "K". I got some made by Norton and they work fine for the Thompson tools and HSS.
Gordon Seto
>Norton 3X "K" 46 & 80. They are almost as good as the Norton SG wheels which cost 3 times more. "J' doesn't hold up as well; easy to get grooving on wheel.
Jim Stoppleworth
>Norton 3X K is what I'll get. Thanks everyone.
RonZ
>I agree with Greg on the Norton 3x as that's what I use. I know they get used faster but that's what a friable wheel is supposed to do.
Doug Thompson near Cleveland
>You can't beat the Norton 3X, personally I like the "K" grade to sharpen the tools, they last for a long time. Matter of fact I just bought (10) 46 grit K grade wheels from Hartville tool in Ohio.
