Trivet question
Trivet question
Trivet question
Jim Rutten
>I have seen trivets where one side has evenly spaced circular parting cuts that go from the middle to the outsider edge and the other side has four or five smaller circles done in a similar way. Enquiring minds want to know how'd they do that? Pictures with jigs would be appreciated.
Re: Trivet question
Re: Trivet question
Cyril Griesbach
>Jim,
Wood Magazine had an article on this about five or more years ago if you can locate an issue.
Re: Trivet question
Re: Trivet question
richie
>check out the router workshop with bob & rick rosenthal. their a father & son router experts who had a show on pbs.they sell the episodes of the series in which one of them is on how to make trvets of which you speak of. really cool stuff.
Re: Trivet question
Re: Trivet question
Ed Wujciak
>I made a trivet a couple of years ago using an idea I saw in Woodturning Design. There were some articles by, I think, David Reed Smith concerning turning thin asymmetrical wooden bookcovers by making a large disc and attaching your "subject" wood with hot glue. Then you fill in the rest of the disc with garbage wood so the whole thing is sorta level. Then you turn the first side, cut through a little more than halfway, and pry off the hot-glued on pieces. Since you didn't put your "good" piece in the middle, it's asymmetrical. In my case, I put it on a glue block to turn the second side, but I guess you could put it back on the disc in a different orientation. The article had some pictures that made the process crystal clear. I hope this helps.
Re: Trivet question
Re: Trivet question
Jim Rutten
>Thanks, guys. I'll keep looking and thinking about how you do this on a lathe.
Re: Trivet question
Re: Trivet question
Bruce Smith
>Jim see if you can get you hands on the March 2004 issue of Wood magazine. They had an excellent article on just what you are looking for. Please let me know if you can't locate that issue as I can try and scan it for you. I was always going to try an turn a couple but never got around to it
Re: Trivet question
Re: Trivet question
>Jim It is done with a parting tool. Hans Weisflog is the first one I saw do it. Maybe you can do some searches and find some photos. I have a necklace pendant that I made using that technique. I'm home today but might be able to take a halfway decent photo of it to show you how I did it. The technique is simple to watch, not so simple to do. The tool has to be very sharp and your depth cuts have to be very precise. Basically you just cut some slots on one side half way through, turn it over and cut some slots on the other side until you see daylight. It's kind of like playing golf. Anyone can hit the ball but hitting it so it gets in the hole with few mistakes is a lot harder.
Re: Trivet question
Please excuse the photo
>This was quick and dirty taped to the back door. I mounted the piece of wood off center. Well actually I mounted 4 pieces of wood together so the corner where they meet was the center. I turned half way through. Then I removed them and mounted one of them using double stick tape so the center of the piece of wood was on center. Then I parted through until I saw daylight. On the next ones I plan to do a little more experimentation to determine where to put the crossing lines.
I didn't like the bulleye center so I stirred some gold leaf into some clear epoxy and turned it into a button to fit inside the pendant.
Re: Trivet question
Re: Please excuse the photo
Jim Rutten
>Hi John,
Thanks for the info and pics. My question though is how you make the 4 or 5 evenly spaced circles on the back. Hans Weisflog bowls are georgeous but I have never seen a write up on how he does it. That's what I am looking for. Thanks.
Re: Trivet question
>Jim That's what I tried to explain in the first post. One side is turned off center so that there are 1/4 circles in that piece of wood.
Han's turns a bowl with evenly spaced grooves going from rim to the bottom on the inside of the bowl. He has a specially ground bent parting tool to do this. It would be easy to make from a screwdriver.
Then he turns the bowl around and mounts it in such a way that one side is faceing the tailstock. If you imagine putting a bowl on top of trailer ball and then tilting it so the rim runs at an angle you may understand what I'm trying to describe. Then you turn a series of circles(maybe 3 or 4) half way through. Then you rotate the bowl to a new blank area and do the same.
This could easily be done by turning a waste block that looks sort of like a trailer ball. Then use blue masking tape to hold the bowl on the wasteblock.
I have to finish a flat wood project today or I would go and turn one. It should not take long. We'll see how my flat wood project goes and I'll check back. I tried to find one of Han's pieces but my search didn't bring up any photos.
Re: Trivet question
Dick Hines
Re: Trivet question
Dick Hines
>Jim go to www.tidewaterturners.com. There some trivets on their sight.
Re: Trivet question
Re: Trivet question
Jim Rutten
>Hi Dick,
That is excactly what I am talking about, but I didn't see how they did them on that site. I know sometimes I can be incredibly dense and I know that some sort of off center turning is required. My question is what did the jig or whatever he used look like. I have been thinking of simply drilling holes and using a screw chuck but, in order to look decent, the holes would have to align with one of the parting cuts on the front and be small enough to fit into the parting cut or it would look tacky. Thanks for all your help.
Re: Trivet question
Re: Trivet question
>Jim Can you describe what you are trying to turn. I can probably show you a jig to hold it. I didn't finish my flatwood project until late last night so I didn't have time to do the bowl.
Re: Trivet question
Re: Trivet question *LINK*
Cyril Griesbach
>Jim,
The page in this link did not load well on my screen but on the left is a photo of the project I think you're talking about and you can get the plans and/or article from Wood Mag for a fee.
Trivet Pursuit
Re: Trivet question
Re: Trivet question
Jim Rutten
>Hi John,
Follow Cyril's link to Wood magazine. That is what I am after. Thanks.
Jim
Re: Trivet question
Re: Trivet question
>No problem. Turn the bottom. Then make yourself a large wooden faceplate. Then make some wooden blocks that you can screw down to hold the platter off center. About 4 would probably work. You should be able to rotate the piece without moving the hold downs so that you could do 3 different centers. Just loosen the hold downs after turning one of the top side circles and rotate the piece 120 degrees. Clamp it back down and turn another set of circles.
Re: Trivet question
Re: Trivet question
>Mount the blank to a faceplate using double stick tape or hot glue. Turn a series of rings about half way through. I used a 3/4" piece and turn grooves 3/8" deep using a parting tool.
Re: Trivet question
Step 2
>Now Draw 3 lines 120 degrees apart. Decide where you want the circles on this line and make a mark. Now use the tailstock to center the piece on this mark. Then use your homemade blocks to lock it in place. Then turn some more circles until you cut into the circles from the other side. Then rotate it and to it 2 more times.
Re: Trivet question
Re: Step 2
Jim A. Rutten
>Thank you, John, That is what I am looking for. Appreciate all your hard work and especially the pictures.
