Using Hot Melt Glue
Richard R. Steussy
>One of the most-used tools in my shop is a 2-temp glue gun I got from Ace Hardware. Every time I mount a bowl blank, I put 4-5 drops of hot-melt evenly around the outside edge of the blank. I then bring the tailstock live-center forward in the circle center to press the bowl blank onto an MDF faceplate. Don't use too much hot-melt or you'll have to turn it off. If you use it sparingly, you can pry the faceplate off easily after you use the Forstner to get your chuck hole--the MDF will let loose. I find this preferable to screwing the blanks onto a metal face plate. And the sticky-back tape is useless. Vaughn Richmond from Australia did a session at the 2007 Utah Symposium in which he demonstrated this technique. Dick (bowlsaw.com)
