Bowl Gouge...Push Cut or Pull Cut?
Wally Dickerman in Arizona
>Which is your primary cut with your bowl gouge...a push cut or a pull cut?
On the outside of a bowl or vessel, turners usually have a preference on which cut they usually use. The pull cut requires a side ground gouge, used with the handle well down, cutting with the side grind more than the nose of the tool. It's best use is when cutting from the foot to the rim of a bowl on a face grain blank. The push cut is favored by many for roughing out a bowl because a heavier cut can be taken, especially with a side ground gouge. The cut is made more on the nose of the tool and with the handle closer to level.
Which cut do you most often use? Or do you use the pull cut at all? Some turners don't.
Wally
