Have a question? Ask Woody!
Please help with PM 4224 controller!
Roger Dunn
Roger Dunn
>I went out to turn this chilly a.m. and my lathe wouldn't run. It has power, the spindle lock is free but no fiddling with knobs and switches in the controller panel will get it to run. When I hit the "Jog" switch on the face of the controller, the motor engages but as soon as I let up on the "Jog" switch the little red light in the panel's display goes from 'run' back to 'stop'. The reset button is no help nor is tap dancing on all of the buttons, unplugging the power and replugging it from the wall. Has anyone experienced this with their Powermatic 4224 and if so is there something I can do before waiting for their tech support to open tomorrow?
Thanks from an electronic idiot!
Re: Please help with PM 4224 controller!
r thomas
>Roger, Mine has a remote switch which at times gets dust in the contacts and will not work. I took ths switch apart blew it out worked fine. If you don't have a remote switch I have no idea,hope this helps . R Thomas
Ralph
>Roger
Blowing the dust out is probably the best first step. Dust and electronics don't mix well. I know that dust can cause similar issues on the DVR I have (and the one the club has). I routinely blow my lathe controls out to prevent this.
Of course it would also be a failure in the circuits, in that case a call to repair is going to be your best idea.
If it turns into a trouble shooting exercise, get intouch. I may not know everything about woodturning, but I know electronics purty well.
TTFN
Ralph
Roger Dunn
Roger Dunn
>Thanks both of you for the help. I'll try to blow out.
Roger Dunn
Blowing it out did the trick! Thanks!!!!!!!
Roger Dunn
>The Jet 1642 has this problem too. Fine dust gets not in the contacts but in the mechanical detent ring and prevents switch operation. When this happened to mine it was a pain to get it apart for cleaning. On the advice of the the local Jet service guy, I sealed the back of the switch. I wrapped it with plastic stretch wrap and fastened with tape. No more problems so far.
Dick Hines
Dick Hines
>I have a PM3520 and I have had some trouble with dust in the contacts of the switch. Your switch could also be going/gone bad. If so they are easy to change out.
Hope it's just dust.
