Turning bun feet/pedestals advice
John_in_Az
>Hello folks, My special daughter has asked me to make some bun feet pedestal supports for my grandsons' twin beds. They will be 5" on major diameter and 7" tall. (I need to turn 6 per bed). I don't consider myself a turner but have turned items as needed over the years on my old junk Craftsman lathe.
I would value some advice on how to proceed on this task. I plan to use glued up poplar of which I have a good supply and the feet will be painted. My questions involve the best way to mount this size turning. Ie: face plate individually, or maybe two at a time using tailstock support and separating? Please help me out here for safety and convenience. BTW, It is in my future plans to get a good lathe and do a lot of turning, but got too much on my plate to slide down that slope yet. Thanks, John
Re: Turning bun feet/pedestals advice
>John I would glue them to a wasteblock on a faceplate with the top of the Bun foot glued to the wasteblock. Bring up the tailstock and turn the foot. Remove the tailstock at the last minute to finish what will be the bottom of the foot. Then use your parting tool to start cutting what will be the top of the bun. You can probably undercut the center portion. Part down to as small a tenon as you dare and the cut it off with a handsaw with the lathe off. Carve the rest of the tenon away. Then true up your wasteblock and glue another one on. If you have enough wood do away with the wasteblock and screw the wood directly to the faceplate. Just remember to allow for the screws. when you start turning.
Ruth Niles
>John, you don't need to go through the glue up process unless you are short on wood, which it doesn't sound like that's a problem.
You're making way too much work for yourself. Just put it between centers and turn the whole thing. The bottom has to be flat to sit on the floor so it's not like you need a perfectly finished end. The top is going to either have a tenon to glue into a hole in the bed or glued to the bottom of the bed so both ends can be sanded flat on a sander.
The easier it is, the more you are going to want to turn!
Oh yeah, one more thing, have fun.
Dick Coers
>Wow, that bed are going to be all feet. 6, 5" dia feet on a twin bed is a lot. Wait a minute, kids jump on the beds quite a bit. Poplar is a good choice, it will turn and sand nicely. If you haven't turned much, you will be suprised how different turning at that diameter is compared to 2" dia of a typical table leg. The motor will be taxed a lot more to overcome the cutting forces at that diameter, plus the imbalance will come into play. How slow does your lathe go? You will want to start at something like 750 rpm. Good luck.
John_in_Az
>Thanks so much for the responses. The largest dia I have turned in the past has been a couple of inches for spindles so have not experienced the dynamics of a larger piece. The slowest speed on my 1/2 hp Craftsman is 875. Wood supply is not an issue so I'll leave an extra inch for mount to the faceplate. Also, for the shape I have designed, the tailstock can be employed at all stages.
As for the overkill on the 6 feet per bed, the feet will be the only frame support. She is making a mattress support perimeter out of 2x4's without a metal bedframe and the feet will be screwed into the 2x4's with double end screws. She was shocked that to buy what she wanted was around 25 bucks ea so I was happy to offer to make her some. Less than 2bf of cheap poplar ea, a little glue, a few hours of my retired time and the enjoyment of doing it = PRICELESS. John
