>I would like to find a reasonable source for 1-1/4 x 8 nylon lock nuts to use for the thread of a wood face plate. I can find the 1" nuts but the 1-1/4" are harder to find and one source was ridiculously expensive. An aluminum face plateplate was less.
As I thought, the nylon-insert lock nuts you refer to at Grainger (or pretty much everywhere else for that matter) are 1-1/4" x SEVEN threads per inch - NOT EIGHT threads per inch. These will not likely work on standard 1-1/4 x 8 tpi lathe spindles.
I have used the 1" x 8 tpi nylon-insert locknuts on lathes with this spindle threading, but I don't think you will find a source for the 1-1/4" nuts with the correct threading unless they are made in a cu$tom order.
Grainger does have heavy hex 1 1/4-8 and I would think you could turn out some thread if you still need the recess for 1 1/4-8 spindle.
Use the reg nut picture on Grainger web site and in pull downs put in the thred and it should bring up the heavy hex. The link I tired to post does not work right.
They are like $24 for package of 5.
Fastenal has the lock nuts but about $32 list price each!
>Our local Fastenal store has 1-1/4" steel nuts in stock on the shelf for around $4.( I could not find in the on-line catalog) I purchased a couple along with 1-1/2" washers. After drilling 3 holes in the washers, I welded the washer on to the nuts and had some quite adequate faceplates for around $5 each. My PM 3520 spindle is longer that the nut so I use another washer for the nut to jam against.
