Piercing
Piercing
Piercing
cagey59
>Looking for some help. I am about ready to start my first piercing. It's a black locust bowl with a rolled over edge. I have placed grooves 3/4" apart on the edge and would like to do the piercing between those grooves. The thickness is not as thin as it should be, about 3/32". Had some vibration and got scared. Will be sanding today and hope to get started with the piercing tomorrow. Will be using my Dremel.
How to get started? Drill holes evenly around the area? Or just start randomly?
Thanks,
Ken
Re: Piercing
Re: Piercing
>Your going to need a lot of patience to pierce a wood as hard as Black Locust that is that thick. Piercing is easy when the wood is 1 to 2mm thick and your using a 400k grinder. With the Dremel the bit want's to follow the grain so take small cuts and pretend that you are carving instead of piercing.
As far as the pattern goes, it depends on what you want it to look like. Binh Pho likes random patterns that aren't repetitive. That's harder than it sounds. If your like me you tend to want to so shapes that are consistent. I try to imagine a giraffe's pattern in my mind to help with the random pattern's.
The Dremel is really bad at actually piercing. Use a drill to make holes first. The Dremel does pretty good at enlarging and shaping these holes. Most people just cut but I find that I need to sketch to help make the solid lines left between the piercing more even. It also lets you drill the holes in better places.
Decide in your mind that it's going to take a while and just work on it a little and then put it down and do something else. Then come back to it. You will do a better job. Good luck. Looking forward to seeing it.
Re: Piercing
Re: Piercing
Ruth Niles
>Ken, I've pierced black locust and it is hard but you shouldn't have a problem. I use dentist drill bits. I do drill tiny holes only where I'm going to do a tiny piercing. Like John said, the bit wants to follow the grain. I hold the dremel at a slant so the bit isn't going straight down, rather resting my hand on the turning for a little support. I don't think 3/32" is going to be too thick, you really wouldn't want the rim of a bowl any thinner than that because people might break the pierced part picking it up and handling it...unless you plan on putting it under/behind glass.
This is a design I've been playing around with, it's a practice piece and it is at least 3/32" thick. I did draw the trees first but usually just do random piercing.
You'll do just fine and have fun.
Re: Piercing
Re: Piercing
Cagey59
>Thanks to all for the input. I will do this first one by drilling holes. So the holes will be laid out and drilled and the piercing started today. I will post a picture when it is done.
Thanks again for the suggestions.
Ken
Re: Piercing
Re: Piercing
charlie belden
>You didn't say if you have a flex shaft and hand piece attached to the motor or an All In One - motor and chuck together - Dremel. Flex shafts give you a little more control.
Here's a tip from my jewelry making days (daze).
You've got things you must coordinate - holding the piece and holding whatever's holding the spinning cutter (bur/drill). When you have everything touching each other - the piece, the left hand and maybe knees holding the piece and the other hand holding whatever is going to do the cutting - it's a lot easier getting them to work together and cut with control.
Higher rpms means more - and lighter - cuts per second. More, lighter cuts means there's less chance of the bit or bur trying to bite off more than it can chew. If that happens, since the "chewee" won't move - the "chewer" will - and if any of your body parts are in the path it wants to travel - it WILL chew YOU.
Which introduces the effect of grain. Cut "downhill" and all will be well.
............V
........................V
Cut "uphill" - and you're asking for trouble. This is called "climb cutting" and shouldn't
be used unless there's no alternative.
Woodcarver Nora Hall uses a broom analogy to show the importance of the direction of a cut. If you are cutting acrossed the grain - even at a shallow angle you can cut the bristles of the broom without a problem. But if you try to start a cut from the ends of the bristle - the bristles spread open. The latter will split the wood or tear it out - very quickly - as in SUDDENLY.
If the wood can't split or tear out - the cutter will be the thing that moves - SUDDENLY. And if YOU or any part of YOU is in the way . . .
The Don't Bite Off More Than You Can Chew thing can also suggest taking small bites - by going with smaller increments - sort of like routing a groove in two, three or four "steps". Smaller bites means more control - and less likelyhood of getting bit.
Hope that makes sense - and is of help.
