Jamieson boring rig - - construction update
Pete in Holland, MI
>Hey all -
Thanks for all the feedback last weekend, even from "the man" himself!
By the end of this weekend, I should have the outer tool rest completed. I also have the tool handle all bent up and ready for a boring bar, which is also this weekend's project.
I have seen on various sites that some people put the 3/16" tool bit directly in the boring bar, either straight, 45 or 90 degrees to center-line. I also see on Lyle's site he has a 3/8" rotatable tool holder for the boring bar.
Questions:
1) Is Lyle's rotatable tool holder what will be used for roughing and finish turning, or is a tool bit directly in the boring bar better for rough turning? Or is it a luxury & not needed? Is his the one to use or you having better success with other designs?
2) Is the steel-on-steel an adequate surface for the handle and outer tool rest to bear on, or is it better/worse to have a dense plastic (nylon or UHMW) on the parallel bars of the outer tool rest? Would assume the plastics would make the system a bit quieter too ?
Anxiously awaiting hearing about your experiences !
Pete
Re: Jamieson boring rig - - construction update
>I think the steel on steel is fine but lubricate it with parafin. It will slide like it's on butter if you do this fairly often.
The swiveling tip is very useful to reach into some places and almost essential if you want to use the Hunter tool tips and use them in the bevel rubbing mode. It's not a have to have thing but sure is nice to have and can solve some problems. I made my first one by cutting repetitive cuts with a hacksaw and then hand filing the rest of the slot to size. It's much easier of you know someone with a mill or if Lyle will sell you one. Unless your really good with a file it's hard to make one that equals Lyle's. Everything just isn't quite flat enough so it doesn't lock down as easily or as securely. I learned to use a file while doing camera repair so I can cut almost anything very accurately if needed.
paul waddle
>john,if possible,please post a picture of the rotatable tip and others. Thks,pw.
Lyle Jamieson
Lyle Jamieson
>The swivel tip will open up possibilities not available to dedicated cutting tips. Photos of mine are on my web site.
The back rest is best metal on metal. The plastics work for a while but eventually cause a drag on the fingertip control I like.
Lyle Jamieson
Here-tis
assembled
Re: assembled
paul waddle
>Thanks,John. Ifn hit haint too high,I'll buy,ifn hit is,I'll lathe and file. pw
