Tips on using PC Wood Petrifier
Dave Mount
>I have some sugar maple bowl blanks that have some punky spots in them. They're green now, but I don't want to invest time in rough turning them if I'm just headed for trouble trying to finish them later. I can turn a tenon in good wood to keep a safe hold on the things, but there will be some substantial spots in the walls that will be soft.
I've been Googling and reading about stabilization alternatives and it seems like Protective Coatings Wood Petrifier is a favorite for many people. However, I've seen relatively little on exactly how to use it, i.e., at what stage to apply it, how deeply it will penetrate, whether to do the whole bowl or just the punky spots. Can anyone share some tips?
Thanks.
Dave
Re: Tips on using PC Wood Petrifier
Chuck Engstrom
>Hi Dave -- one of the fellows in our club once used some stuff called Rot Doctor (www.rotdoctor.com) and got good results from it. He said it was pretty expensive but quite effective -- very thin and slow curing so it soaks in slowly but thoroughly. I saw a bowl he used it on, can't remember what wood it was, but the result looked first-class.
I can put you in touch with him if you'd like.
Best--
Chuck
>Dave I just use thinned lacquer. It penetrates very well. You do need a bunch of coats if it's really punky but it will make the fibers stiffer so they cut clean.
Hugh Widdup
>I tried the thinned laquer but i found when I went to sand the piece the paper clogged up quickly,
John did you find this or is it just me...maybe you do not need to sand :)
