More on threading boxes? Long..
paul waddle
>I've just finished reading part of Fred Holder's book on cutting threads in wood. Saving the hand threading for last.
Fred discusses Bonnie Klein jig,Nova orinmental jig,and Beal jig.Each works differently todo the threading. There is one outstanding feature of the expensive Nova jig(involved with threading that is),one can loosen the "grub" screw (American is set screw ha ha),swing the chucked up box part,and test the thread fit. I suppose,if the threading screw is long enough,you can back it off on the BK jig or put a stop on the lathe bed and loosen the complete jig and pull back and return to start without loosing accuracy. I have to back off my cross feed 4 complete turns to do so,then go back the same amt. I manage,but there's a place where inaccuracies can result if too much slack in the cross slide screw. Best to lget a good fit first cut...
There is one question I cannot understand: when cuttin the outside thread on the male(bottom part),its climb cutting? I guess it is a moot item,but for a right handed cutter,it has to put more pressure on the threads. Now its not dicussed,with the Nova and BK jig,one can start at the rear shoulder of the box and cut the thread backing out the feed screw... I've tried this,it works,but makes no difference that I can discern.....I believe with the Beal jig,one can reverse the feed and use a left hand cutter...hmm.wonder how that works...pw
