turning pens
turning pens
turning pens
Zak Schutte
>im having a problem with turning
the pens always break on me
is it the knives or am i giving too much
pressure or what?
Re: turning pens
Re: turning pens
Grant Wilkinson
>Zak: More information, please. When are they breaking? What is the material? What are you using to turn it with? Are you using a pen mandrel, turning between centers, something else?
Re: turning pens
Re: turning pens
Dick Coers
>One of the most common mistakes, by beginning pen turners, is poor glue procedures. I use either 5 minute epoxy or Gorilla glue. Rough up the brass tube with 80 grit, and make sure you rotate and slide the tube back and forth as you insert it. Good glue coverage is critical.
What chisel are you using. If you are using a scraper, some woods and figured woods will be very difficult. I use a skew all the time now, but started with a spindle gouge.
Re: turning pens
Re: turning pens
Roger Peterson
>Zak,
I agree with the quality of glue being a factor in pens coming apart. Also consider how sharp your knives are, a sharper knife will require less resistance to cut the material. Check the quality of your wood, are there cracks or weaknesses in the wood?
I am interested in hearing more from experienced turners about lathe speeds, glue up techniques, and types of glue recommended for pens.
Re: turning pens
Re: turning pens
Ed Conhaim
>Started penmaking using thick CA glue and hated every minute of it. While most of the time the glue held (not all the time), the mess and glue on fingers was a real pain. A highly experienced penmaker in our club suggested SUMO glue as the better urethane glue compared to Gorilla glue. It is from the same company but supposedly does not foam as much as Gorilla glue. The only problem is that the set up time is basically overnight. I got around this by glueing up a group at a time.
Re: turning pens
Experienced? Not much.....
Al Neighbors
>I'm not really what one would call experienced, since I've only turned about 50 or 60 pens, but I'll tell what I use.
I've tried CA gel, CA thin, and Loctite 5 minute epoxy. I now use 5 minute epoxy only. I keep 4 or 5 sets glued up, and never have to wait for a cure time... when I get to them they're ready. I can glue 4 or 5 tubes with one mix, before it begins to set up.
Re: turning pens
Re: Experienced? Not much.....
GalenV in Iowa
>For those of you that turn more pens than I, it seems I started with medium CA on wood and then went to the flexible CA on plastic as that is what was suggested to me.
If you use 5 minute epoxy and/or urathane glues I guess I thought being a more thick bodied glue it would skim off a lot trying to put the tube in a close fit hole. When I read of using these glues it seemed a plug was made for the tubes just to keep out all the extra glue. That sounded like more work/mess.
Do any of you use a larger hole than kits suggest or just use a method to thinly spread the glues so there is less to skim or apply glue to inside of wood before putting in the tube?
I have wondered for the pens given away if anyone tried to put in a new refill or twist to operate over time if the CA would let go. No complaining from the give aways but then for free not sure if they would say.
I never was able to get CA glue to work for much of anything till I did pens so that is why I am still always a little skeptical.
Any other comments you can make on your usage may change my mind on glues to use.
Thanks
Galen
