Polymer Clay Pen Blank?!
DavidWalser
>I came home today from work and was greeted by two pen blanks my wife had made out of polymer clay. Any of you ever turned this stuff before?
If you're not familiar with polymer clay, it's a clay-like plastic compound that can be molded and shaped and then cured in a home oven. Once cured, it's hard like a ceramic, but it's not brittle and can be sanded, drilled, and carved.
Re: Polymer Clay Pen Blank?!
Ralph
>I haven't, but there is a section on it in "Turning Pens & Pencils" by Rip Christensen and Rex Burningham
Steven Kubien
>There was also an article in Woodturning Design a couple of years ago. IIRC, in the article they wrapped the clay around the brass tube and them baked it. Let us know what it is like to drill.
Cheers,
Steve Kubien
Jeff Taylor
>I went through a 'clay phase', and enjoyed the look of polyclay pens .. they do not really shine like acrylic, but since that time, the Wipe-on-poly finish has come-to-light and would likely make a very fine durable finish .. I used a CA finish and sometimes no-finish ... I made one particular keychain which still in daily use by my assistant. It is a few years old and is now starting to chip .. but it is a keychain which get a lot of abuse ...
Thanks!
DavidWalser
>Jeff,
Thanks for your input. I appreciate the help.
David
Scott Greaves in Blackfoot Idaho
>Hi David,
I played with polymer clay pens for a while. Fun stuff, although it can be brittle enough to break if you drop it. If your pen blanks are solid and you need to drill them, be very careful, it can crumble easily if too much force is applied. The best way is to wrap the clay around the brass tube and bake them that way. Use light cuts when turning. I never used a finish on the clay pens I made, and that is something I would change if I did it now. I'd do at least a CA finish, although a wipe-on polyurethane finish would probably be good as well. If you really want to try something cool, apply the polymer clay in intricate patterns over the brass tube, but very thin. Then after you bake it, cast it in polyester resin and turn. That could be very cool! Good luck!
Scott.
Grant Wilkinson
>I've done several of them. Over time, I found that the "no finish" ones did not hold up in daily use. The latest ones that I've done, I turn shy of the final size and cast them in Alumilite. I don't wrap the tubes with mine. I finish the blank, then drill it. Each to his own, though.
Re: Polymer Clay Pen Blank?! *LINK*
Ed Davidson (Colorado Springs)
>The Polymer Clay pen turning article I wrote was in the Summer 2004 (issue #2) of Woodturning Design...back issue link below. And this is the pen that was featured in that article.
Woodturning Design Magazine
