How to bore a tapered hole????
Adrien
>Friend's monkey wrench had wood over iron handle. The wood part broke and he asked me to make a new wooden sleeve. The core is 3" long, tapers from 1/4" at one end to 3/8" at the other. Rather than just a 3/8" hole that gets filled with epoxy, I'd prefer a closer fit.
Any suggestions how to drill a conical hole?
Re: How to bore a tapered hole????
arkie
>Assuming you can hold the handle to drill all the way through, and have a set of regular drill bits available, drill 1/4 all the way, from the end you want 3/8. Go to your next size bit, and bore most of the way,and continue, making a stepped hole. if yu have every 1/16 size, you can get close enough to a taper as makes no difference.
Thanx Arkie. Will try it.
Adrien
Burn, Baby, Burn
>Adrian,
That kind of handle was usually "clenched" by heating the tang (same as on a chisel) to the point where the tip was red hot and much of the rest was very hot. The iron is then pushed (fast) into the wood handle and literally burns the taper as it goes. As it cools the wood lignin that has melted fuses to the iron surface cementing the handle in place. All of my carving chisels are handled that way and I wail on them with a 2 lb maul with no effect.
Re: Burn, Baby, Burn
Adrien
>Mark, thank you for your suggestion: I thought of that, but this is an antique, of iron, not steel and I was afraid that heating the tang might change the temper of the spring and hinge in the pipe wrench part. This was his boyhood toy and has great sentimental value to him.
There's a picture of one at
http://redding.craigslist.org/tls/991866507.html
And for ten bucks it would've been a lot easier to just get him a replacement! However Arkie's method worked and no harm to the wrench.
paul waddle
>You say 3" I'd make a tapered pc of steel after doing what Arkie suggested. Sharpen the appropriate two edges,and use a drill press as a driver-gently as it will want to grab. A little more sophisticated way would ask some with a metal lathe to make you a tapered bit from 3/8stock. Flaten to 1/2 diameter and sharpen the correct edge, and undercut for clearence. Although not tapered,I've made some drills to cut escheution(sp) for pistol handle screws. They work... pw
>Mark layed it out for you. Drill a 1/4" hole close to the depth you need. Heat the tip of the tang to almost red hot. Then drive the handle on. I clamp the tool in a vice with wood protecting the blade. If your worried about heat damage to the blade simply put a pair of vice grips on the bottom near the tang. The vice grips will soak up the heat. I've done this many times and it works perfectly.
arkie
>That's the way I'd do it were it my own, but it's not the question that was asked. :)
Make a Reamer
Re: How to bore a tapered hole???? *LINK*
Dick Coers
>Just for reference for next time, a wood taper with saw steel to scrape a taper.
saw steel reamer
Lee Valley has nice tapered reamers *LINK*
>I've got a set as well as a nice mechanics tapered reamer.
Lee Valley
what a great bunch!
Adrien
>I used Arkie's method. It was great to get such a quick and helpful response from the message board members.
