Drill Chuck Help
Drill Chuck Help
Drill Chuck Help
Tom Minehan
>My drill chuck has developed so much play both axial and radial that it is useless. Is this a function of the forces encountered on a lathe as opposed to a drill press or because it was an "el cheapo"? Those that I find in the turning catalogs seem to be the same quality as what I have now. Any suggestions for a source/brand that may hold up longer?
Re: Drill Chuck Help
Curly Smith
>If you only use a few sizes of bits then you might consider switching to Morse taper drill bits. Depending on your tailstock you might also need a Morse taper adapter.
They are available in a number of places such as in this link to Enco: TAPER SHANK DRILLS
>Tom I use the Keyless chuck from bestwoodtools. It works superbly and has for about 3 years now.
Pete in Holland, MI
>Jacobs has always made a great chuck. Not cheap though. In new is out of the question, watch e-bay, or I often see them at antique stores among the old tools. If the tang is not the right size for your lathe, order a new one. Research the chuck number against what kind of taper is in the back of the chuck to match up with. Jacobs had their own taper in their chucks, which has pretty much became a standard.
Picked up my chuck and #2 morse taper tang for $6. Keys are often not there, but can be ordered.
Russ Fairfield
>Just a personal opinion, but I have had good performance from the Golden Goose brand sold by Woodcraft and Craft Supplies. Two of them are almost 20 years old, and I am not a part-time woodturner. They are still tight and accurate. Nobody I have recommended them to has ever complained.
Ditto on the Golden Goose Drill Chuck
Gil Jones
>Mine is a keyless, 1/2" capacity, with a #2MT adapter. It is going on 5-years old, and looks / works like new...no slop...Also, it is from Craft Supplies USA.
Gil
Re: Ditto on the Golden Goose Drill Chuck
Richard Jones
>Ditto again...........
Rich
Thanks!!-Problem Found
Tom Minehan
>Thanks for the responses especially those that referenceed "Golden Goose". I thought I bought the chuck at Woodcraft. I was not familiar with how various chucks were assembled. I did some research and found some used a taper similar to morse taper to mount the chuck to the arbor. I looked at my chuck and found it was a "Golden Witch" marked JT33. The arbor was what was loose and causing the play. Some not so friendly persuasion got the arbor out of the chuck body. The arbor has some galling that was causing it not to seat. Some careful dressing of the mating surfaces seems to have fixed to problem. Looking at the chuck assembly it appears that a bit can be inserted far enough into the chuck jaws to push on the end of the arbor and unseat it. I never paid any attention on how far I inserted a bit as I didn't realize that the arbor was a seperate part.
Re: Thanks!!-Problem Found *LINK*
Don Evans
>Tom, glad you got it working. Just FYI, if you ever need to remove that chuck from the arbor, there are wedges made to do that job. You can get them from MSC or ENCO. They're about $6.00 per set so good idea to order them before needed when making a order from anyone who sells them.
Some of these arbors are JT (Jacobs Taper) on the chuck end and some of them are screwed on. Generally the arbors that need the wedges will have a small channel in the shaft just below the JTaper, thats where the wedges slide in. Other end of arbor is Morse Taper (generally, most common).
Don
Jacobs Wedges
