On the topic of buffing: thin objects
Steven Antonucci
steve antonucci
>For those of you that have buffed thin objects before- how thin is too thin? What speed do you run the lathe at? Is there a minimum thickness before you decide it is just not worth it?
Thanks-
Steve
Re: On the topic of buffing: thin objects
>Steve Yesterday I was showing my latest student a thin bowl that I had buffed. It is approximately 2 to 2.5mm thick. I buff them with my usual 4" wheels at aproximately 1000 rpm. This was bass wood which is quite fragile. Always buff out toward an edge, never into the edge. Of course that should be true no matter now thick you buff. The same is true if it has any voids. buff from the solid area toward the voids, never across them or into them.
Wally Dickerman in Arizona
>I regularly buff pieces that have 1/16th in. walls. I sometimes lightly buff with white diamond on a surface after I've done a piercing job on it. I'll admit that I sort of hold my breath when I do that. I've never had an incident when buffing. I'm never very aggressive when buffing.
Wally
Steven Antonucci
Thanks Wally and John
steve antonucci
>I slowed my wheel down considerably and buffed out a small vessel that I made this weekend. It looks pretty good as a first pass on my homemade buffing wheel. I tried to use it at 1000rpm, but it didn't do much, so I set it to 2000rpm and that did the trick. Overall, about 1/8" thick, no issues.
Sanded 1000 grit, buffed with white diamond, then buffed with carnuba wax.
The next one is the hairy one (some voids, some wood of questionable integrity...)
Steve
Re: Thanks Wally and John
Cyril Griesbach
>Steve, why do you think you needed to increase the speed to get the wheel (I assume it's your new home made one) to become effective? Do you think it's because it's not spiral sewn? Would larger flanges help to stiffen it?
Steven Antonucci
That might be the reason
steve antonucci
>It basically mushed down to nothing at 1000 rpm. Upon increasing the speed, it was fine. There was probably a middle ground between 1000 and 2000 rpm, but I just moved the belt over 2 notches.
I may just throw a couple of simple stitches in it to see what happens. A work in progress...
Steve
