Lathe Demo setup for safety - Polycarbonate Window
Tinkerman
>I'm setting up my Jet JML-1014VS Minilathe to support demos and am looking for guidance on what to use for a safety shield in front of the lathe to protect observers from any flying debris and protect the general public?
I was thinking of using a 24"x30" sheet of clear polycarbonate slid into a set of grooved holders on either side of the lathe stand, but was wondering what thickness would be sufficient? Do I need to go up to 1/4"?. Anyone have suggestions for sources... do the big box stores carry this? What other techniques have you seen that work?
Re: Lathe Demo setup for safety - Polycarbonate Window
Don't screw up- then any thickness will work :)
>Seriously, when I do demos for the general public I do smaller things so there isn't any danger. I did do demo's once for the Empty Bowls project and had to do bowls. I picked my wood very carefully so that I know it was solid with no defects. I didn't want to take a chance. I set the lathe up so the public was generally out of the line of fire.
Dick Coers
>I can suggest that you make those grooves pretty deep. Polycarbonate will flex a "ton". If you make it a full width panel, and don't have a top support, a hit may pull the sheet out of the slots . A vertical center support will half that flex. Usually the storm door replacement panels are poly. I do suggest using 1/4 for a full width panel, but if you get a good price on 1/8, put in two sheets. If you half the width, I think 1/8 will do.
Ian
>this is the setup that we (Massachusets South Shore Woodturners) use for demos. we have 3 lathes set up this way now.
a workmate style stand with a ply box draw storage and tool holes in box. the conduit is 1/2" emt and 1/2 in galvi clips. there are screws thru the clips into the conduit to hold everything in place.
loosen the two set screws on the elbows and the whole shield is removed.
IAN
Bill Blasic
Bill Blasic
>I used Lexan for the guard in front of my 1220 VS for demos. At $72 it was expensive but I know that nothing I'm turning is going through it. My club had been using Plexiglass as guards but while demoing at a function where a young child had a few seconds earlier had been right in front of the lathe a piece came off and went right through it. Not only did it go through but two pieces came back at two of us sitting behind the lathe (ver jagged pieces)and went between us. We were very lucky that there were no injuries. That is why I chose Lexan.
Tinkerman
>Thanks for the pic. Look like the Lexan is really thick (3/4"?.. can you tell what thickness it is. Did you happen to just use some lexan you had already or did you specifically choose this thickness for a reason?
Ken
>I would go with the lexan.You don't need 1/2 or 3/4'unless your afraid somebody is shooting at you with a 44 mag.I use to put it on construction equip to keep debree from field mowers and such from wackin me in the head (rocks also)and all you would need is 1/8 and I can guaranty that nothing wilolo penetrate it.The big plus with lexan is its flexable and WILL NOT break.You cannot bend it and break it,won't happen.
Wally Dickerman in Arizona
>I've been to a lot of symposiums and I can't recall ever seeing a glass/plastic safety shield used. Just attended the Desert Roundup last weekend. No shields there. Why do you think that you need it?
Wally
From a Viewers standpoint
GalenV in Iowa
>Having gained my final interest in turning by watching the Ames turners at the local mall or on main street during the Arts Festival.
When you out where there is general public it is probably safer to have the shield. If you are attending a more controlled demostration you may not need or even a disclaimer existed you signed when you registered.
The main thing I saw was some shields were at a height when I really tried to see how a cut was made the top of the shield was right in the line of sight, standing with my nose close to see!
Ian's shield would sure allow viewing and he is in no danger of me shooting him with my 44!
Just a viewer and now turner comment.
Galen
Re: From a Viewers standpoint
Ken
>I can understand why someone would want a shield,with the way people wanna sue you at the drop of a hat.If I were to do a demmo,I would get one ,if for nothing else,that reason.
Ian
>since this was the prototype setup it was made with a piece of 1/2 in
lexan, now all 3 setups have a piece of 1/4 in 24 x 30 inch pieces of lexan, a distributers rep told me that the thickness would be more than sufficient and the thicker could lead to viewing distortion . which we found to be true.
not using a full frame allows greater viewing area, and still keeps the viewers at a safe distance from the lathe.
as wally stated at a turning event you usually don't see shields but we demo for a lot of small children and small minded adults. there hands can get to a spinning piece of wood faster than you can say no let alone hit the stop swithch. so the shield keeps fingers clear.
hope this helps
IAN
Re: Lathe Demo setup for safety - Polycarbonate Wi *LINK*
Don Evans
>Here is where I get my plastic's. I've ordered from them to make dust catchers for lathe and carving/sanding station.
http://www.usplastic.com
Plastic
Don Evans
>Guys, Lexan is polycarb, Lexan is just one of the brand names that it is sold under. There are other makers.
