>I recently reground my skew and now experiencing more caches.
My skew came out after grinding,26* included angle and the edge sloped back 70*. I went to Woodcrafters and measured a high dollar(Crown) skew and it measured 35* included angle and the edge sloped back ~58*. Which is the most signicant angle-the included or angle that edge slopes back? Is there a tutorial on the net that shows proper techique? Thks,pw
>The sharper the edge angle, the more easily it cuts but the harder it may be to control, more prone to catches. There was a discussion about this here a few months ago. Darlow recommends 25 degrees which some feel is too sharp. I think John Lucas said he sharpens his to about 40 degrees. 30-35 degrees might be a good compromise.
The other angle, that which slopes back from the point, seems less critical. Some people recommend 60 to 70 degrees. For me the skew seems to work as well with nearly any angle - I have one ground straight across and I tried planing with it and it worked fine except for requiring me to hold the handle in an uncomfortable position.
>John K pretty much nailed it. I tried lots of different sharpening angles on my skew one year. I found just what John said. The more acute the angle the trickier it was to use. Too blunt is also difficult because the bevel gets too short which makes it difficult to stay on the bevel. I found about 35 to 45 degrees is a good place to start. It gives you a good cutting edge, a moderately long bevel, and is a little easier to control.
25 degrees cuts like butter but it's really easy to tilt it too far when turning beads so you have to be really careful. It's great for planing cuts and using the toe to cut end grain. It's also kind of a weak edge and seemed to get dull when I was cutting hard woods.
I have the Darlow book Fundamentals of Woodturning and it is showing a skew angle of 30 degree measured perpendicular to the 70 degree point to heel. Then says if presented at 45 degree the effective angle at cut is then about 22 degree on the rectagular skew.
I, like Paul, have a shallow 26 degree on an oval skew and I think this is killing me for control. Very hard if not imposible for me to make the end grain cut shown in that video. Either going to regrid to the 30 or a little more or buy a rectagular skew, as I used a loaned one easier.
The pictures of both Darlow and the Lancer video look like they use heavy skews anyway. Maybe optical illusion but they look a lot thicker than my 1/4" at thickest part. Maybe easier to see the faces while cutting? Any merit to heavier skews over light?
I have seen pens turned with 1 1/4 or it was 1 1/2" skew!
Yes, there are advantages to using a heavier skew. The additional mass helps prevent the tool from flexing and make it easier for you to hold it steady and move it smoothly. The disadvantage to a thick skew is that it might not fit into a tight spot.
I think the borrowed skew I used was heavier rectagular over my thin oval and maybe it was that it was stiffer too.
It did surprise me to see a turner use a very large skew and still keep away from the mandrel ends and centers. Then if he ever hit, think the tool would just have trimmed those too!
