Inexpensive faceplates
DC Powers
>Anyone know a source for inexpensive faceplates.
I saw a message about some recently, but can't seem to
find it now. I think were made by a guy who did it on
the side for some extra cash.
Re: Inexpensive faceplates
GalenV in Iowa
>Woodturners in our local club all making face plates by purchasing 1"-8NC nylon lock nuts. Turn out the nylon insert so it lets it seat on our Jet lathes. This give a recess to the nut so it seats metal to metal on the spindle face. I true up the metal face at the same time.
Set them in a thick piece of hardwood you have turned for a recess and set nut by epoxy. Diameter of block up to user. When dry put on the lathe and true the face.
Forget if they said they saw this by Bonnie Klein or not.
Glue what you are turning to face and part off when done turning and use again.
I made two.
On a metal lathe I had you could buy companion flanges for pipe and true them up as face plates.
Galen
Tony Shaftel
>I bought a few from Bill Noble at www.wbnoble.com. No connection to him other than that, and enjoying his postings here and there.
Bob Moffett
Bob Moffett
>You can get a tap from Hartville Tool and make them from hardwood. Tap a piece of hardwood the size of your spindle and then glue or screw a larger piece to it. True it up and you have a faceplace. Also, Don Pencil has blems that he sells at a discount every so often. I don't have any affiliation with either Hartville Tool of Don Pencil.
Bill Howatt
>I went the tap route but I only use wood faceplates for light work. I wouldn't use one to mount a heavy, unbalanced bowl blank.
Bill
jared
>I got some from Don Pencil, one of the advertisers here. They are aluminum. They worked good for me. Jared
Texian
>I have some of the Bill Noble faceplates. Acceptable value for the $$. Suggest that you spend the few extra $$ to have them faced off and the threads recessed. I did the former but not the latter, so must use a flat washer between the faceplate "nut" and the spindle shoulder.
DC Powers
>Thanks to all for the good info.
>I went to a local industrial junk yard and bought nuts that fit my lathe's shaft and some Blind Plates. Blind Plates are disks of steel used to seal off large gas pipping. Mine were four inches in diameter, but they also had larger ones. Had a local machinist weld the nuts onto the plates and face them off. Had about six made for a total cost of less than forty bucks. I drilled holes for screws in them myself as needed.
You can buy the nuts for McMaster Carr and have a machinist cut 3/8 plate into disks.
I made some quick attach...
Al Neighbors
>faceplates out of the disks in old VCRs. Put them in a chuck and turned a place for the dovetails to clamp. Then turned them around, and faced them off. Drilled holes for mounting on wood scraps.
They really do work.
