Gluing Corian
David Haywood
>Does anyone know if there is a special glue for Corian or can you use CA or epoxy?
Gluing Corian
David Haywood
Re: Gluing Corian
Ian
>there are color match glues used by the pros for corian, but I personally have had good luck with using Med CA and clamping the pieces together for 20 minutes.
the only failure I had was with a piece i was trying to rush and I used activator and no clamping.
IAN
Re: Gluing Corian
Jim Canning
>Use the color match by corian. The idea is to not see any seems, when you use the color match you can make it any size or shape and it looks like one pc. It may cost a little more but sometime doing things right cost more.
Re: Gluing Corian
JanManuel
>I glue Corian and similar materials all the time with CA glue. I use lots of accelerator too....Make sure your surfaces are smooth and clean, glue on one side, press together, spritz with accelerator if you want....and give it a few minutes to cure.
The CA glue adheres to Corian so fast...make sure you have your alignment exactly as you want it. I put clear packing tape on one side and use it as a hinge.
I've been told by a Corian fabricator that the "official" glue is chemically very similar to CA.
Look at the photos of the lazy susans on my web site. There are many glue joints on each one. I mount those in the lathe to finish the edges and I've never had one break...not even when I've hung a lathe chisel on an edge.
Re: Gluing Corian
JanManuel
>The link to my web site didn't post....here it is:
www.hardtopquilts.com
here is the link *LINK*
>Very nice platters. I may have to try some Corian now.
http://www.hardtopquilts.com/
