question about refinishing bowls
jared
>I recently made another batch of ash plates and bowls and put inlaid turquoise and malachite in a groove close to the edge. I used extra thin starbond CA to glue the stone in. Now about 3 months later, several of the inlays have cracked, only on the sides of the plates that are over the end grain, does that make sense how I described it? There must have been some residual stress or moisture in the turnings that caused a slight shift in the plates causing the fractures in the ca. I have made several of these inlays before and never really had a problem. Maybe the blanks werent quite as dry as I thought. Anyway, I have devised a way to resand and reglue these inlays, I dont want the items to go to waste. They have several coats of finish and then were buffed and waxed with the beal buffers. My question is, will naptha remove the wax on the portion of the plates that wont be resanded, so that the new finish will stick to the old finish? If not naptha what else will work? Thanks in advance Jared
Re: question about refinishing bowls
>I use mineral spirits to get the wax off. It works great.
