THE WOODRAT IS BACK!
Fridge Magnet
Fridge Magnet
Fridge Magnet
Paul Zerjay
>Does anyone remember an offset turning that was a refrigerator magnet? It was just a small little nub looking thing that was turned offset, and had a recess in the back for a rare earth magnet. Pretty cool looking and I wanted to try some more of them. If you have a link could you please post it? TIA
Re: Fridge Magnet
Steven Antonucci
Turn a mandrel
steve antonucci
>I have a couple of dozen of them on my fridge.
If your magnets are 1/2" round, cut a mandrel with a 1/2" tenon about 1/8" long. Take your magnet blank, and drill a 1/2" hole with a forstner bit just shy of 1/8". Jam chuck the blank on the little nub and hold it in place with the tailstock. If you make it fit good, you can remove the tailstock to clean up the nub it leave.
Epoxy the magnet in. CA tends to fail when the magnets fall of the fridge.
Steve
Re: Fridge Magnet
Brian McKearney
Re: Fridge Magnet
Brian McKearney
>This isn't an answer to your question, but another idea that I have done in the past that's good for conversation is to bury the rare earth magnet inside the wood. If you take a couple of pieces of scrap with matching color and grain, you can drill a hole for the magnet in one piece, insert and epoxy the magnet into place, and then glue the two blocks together. You have to use a bit of care when turning not to get down to where the magnet will show, but when you're all done, all that shows on both sides is wood and it won't scratch the fridge. The less wood on the back side between the fridge and the magnet, the better as more wood tends to detract from the magnet's holding ability.
This makes a great conversation piece for those non-woodworkers as you get questions like "how does it stay on the fridge?".
Just an idea!
