Homemade buffing wheel
Steven Antonucci
steve antonucci
>Ever wake up in the morning just knowing that you were going to get things done today? That was me at 6am...
My wife is not a flat sheet person. I don't know why, but she just isn't. Consequently, whenever we get new sheets, there are brand new, unused flat sheets sitting in the linen closet. I confiscated the last one from our new 600 thread count set, and my wife just rolled her eyes...
"What do you want it for?", she asked.
"I am going to make my own buffing wheel", I replied.
"That's nice...", she countered as she lost interest...
This conversation probably took place a year ago. This morning, I set out to fulfill my destiny.
I started with the bigger one. It was folded to a square roughly 8"x8". I traced a circle with a compass and began hacking it off to round with a utility knife. Within 10 minutes, I had a respectable circle.
I turned a face grain block of basswood (what I had laying around, would use maple instead if I had it). My thought was that the face grain would hold the screw better than end grain. This was a mistake, as the face grain split when I went to true it up with the linen circles mounted. I quickly made an end grain block and went back to the project.
To keep the linen "rigid", I made big washers out of some 1/8" MDF (again, what I had laying around). I'm probably going to get some 1/4" aluminum to redo, both of these. The idea was "upgraded" by using some UHMW plastic inserts I had laying around- much stiffer, but slippery. The right balance of stiffness and ability to torque down on the nut to keep the linen from slipping against itself and the washers will probably be by using a metal disk or large washer. If I can find a cheap washer to avoid making them, that's what I'll do. If not aluminum will be used to turn them.
In these two prototypes, I tried different things. The smaller one is made from leftovers, and I used a through bolt against the disk. The original just has the single deck screw holding everything together. I think that the through bolt is probably the better idea, and I will eventually retrofit the larger one later.
Once everything is connected together, the wheel needs to be trued. I decided to do this the the long point of my skew with the lathe running at top speed. This works absolutely perfectly. I was amazed. I took an out of balance wheel to completely round in 3 passes with the skew.
[Soapbox on]
So, I am guessing a few of you are reading this and thinking that a buffing wheel is so inexpensive, why would anyone be crazy enough to make one? At the risk of sounding corny, I am being "green" (at least I am trying to be.)
I am working very hard at looking at things from two aspects: sustainability and environmental friendliness. If I had discarded the sheets, they would be sent to a landfill where they would biodegrade. Cotton is probably not the worst thing to put into a landfill, but it still can be put to a better use. As a buffing wheel, these sheets will now have a much longer life than they would have as bedsheets.
The sustainability of cotton is bettered by not consuming the resource. By taking the material and repurposing it, I lower the demand for the the resource. Granted, it doesn't amount to much, but if everyone started to think this way, it would matter. So, I've decided to start with ME. I am changing my consumption of our resource in the hopes that others will join me.
[Stepping down from the soapbox]
So, for about an hour or so of my time, I now have a way of making "free" buffing wheels from post consumer materials that only costs me time. I plan on having many wheels with various compounds, and since they are all held by a chuck, I can switch them easily when I need to.
If anyone has any questions, please feel free to e-mail me. What you slept on last night could be buffing the bowls you eat from tomorrow...
Steve
Re: Homemade buffing wheel
Al Neighbors
>Steve, that's a good looking wheel. I know what you mean when you say you're saving some otherwise tossed material.
I built my own buffing system, and now have 8 different wheels that I use. I have a short tutorial in a .pdf file, if you want it... you might get some different ideas for mounting and switching wheels. Just remove the REMOVE in my email, and I'll send it to you.
paul waddle
>Good job Steve,both for your buffers and your vigor on a Sat Morn.pw
Texian
>Looks good Steve. How many layers does your wheel have?
GalenV in Iowa
>Could you clamp between light ply or masonite and cut with a band saw?
Mine may be a little rougher as I sleep on "sandpaper" sheets that are not 600 thread count.
I do have some old blankets and wonder if they would be too open weave for a buffer. What do you think?
Old denim from the jeans I don't seem to fit in but never throw out?
I have made small buffers just using long nap paint rollers but I consider them short life.
Would not have thought about the recycle use. Thanks for saving our planet.
Galen
Steven Kubien
>Nice work Steve, on many counts. Can you explain how you trued up the wheel with your skew? That sounds like a disaster in waiting.
Cheers eh,
Steve
Steven Antonucci
Thanks for the thoughts and some answers
steve antonucci
>Thanks for the kind words and encouragement.
To answer some questions:
1.) I thought about the bandsaw and decided against it. I had a pretty aggressive 1/2" blade on, and I figured that I had a lot of questions that I couldn't answer without doing it, so I opted out.
2.) As far as the number of layers, I couldn't guess. It's a King size flat sheet, folded a lot. Could be about 100, I suppose, but that's just a guess.
3.) Old jeans would probably work. Blanket might be my second choice, unless it was flannel.
4.) Steve K. -not dangerous at all. Messy, but no thread of being hit by anything more than linen scraps. The toolrest was placed in front of the wheel, perpendicular to the ways. Using the the long point down, I made a truing cut by raising the handle with the lathe running at 3600rpm. Lower than that, the wheel would just deform. At speed, it cuts the threads like butter, throwing thread scraps lightly through the air.
I'm thinking that one of these could be made in about 30 minutes. Two could be made in about 35 minutes. If you "batch" up the operations, you can cut assembly time considerably.
Give it a shot.
steve
Steve, that's a good idea.
Al Neighbors
>Truing up the wheel on the lathe. I didn't have enough sense to think of that. That's what makes this forum so great! More, and in most cases better, minds. :)
100 % cotton denim makes a really good Carnauba Wheel.
65/35 cotton polyester denim makes a terrific White Diamond Wheel.
Felt makes a good Tripoli Wheel.
Cotton Flannel makes a good wheel, left clean, to re-buff items that need it occasionally.
Steven Antonucci
Can you post a picture of your wheels?
steve antonucci
>I'm most interested in seeing what you've done in the centers. Any support.
As far as truing them on the lathe, it works so well it's scary :-) (without being scary at all)
Steve
I'll try to post a pic...
Al Neighbors
>but I'll explain it, too. I held the circles of cloth between to disks of plywood that I had marked the centers on. Then I drilled a 5/8 hole through the ply and the cloth. 5/8, because I needed it that size. I then put a piece of 1/2" CPVC pipe in the center of each wheel. I had to sand the center of the pipe just a skosh with a dowel and sandpaper, in order for it to slip on and off the arbor easily. I superglued the cloth to the CPVC. A perfect axle for the wheels.
