Jamison boring rig - construction tips needed
Pete in Holland, MI
>Hey Guys -
Am starting on building one of Lyle's boring rigs. Have looked thru the archives, and have a couple questions on your rigs:
1) Regarding the rear captive support; How much clearance is desired between the rails, and thus the sliding arm? Is this a precision fit, or loosey-goosey?
2) Saw photos on one rear captive support rig where the top bar could be unbolted with a hand nut and swung sideways. I assume to get the boring bar handle out of a turning. Is this necessary or beneficial ?
3) How long of a boring bar are you comfortably using? I will be building my own bars out of some 3/4" CRS.
4) Do you use your OEM inboard tool rest, or is it wise to build a new one with a hard surface?
5) Do you use up the entire 38" length of the outboard captive rail support, or can it be made smaller? Or is it too short?
6) Does anybody have any interest in some lasers that can be fed with a 3-5 volt power supply (no more batteries!)? I picked up a bucket full of them at an industrial sale several weeks back.
Many thanks !
Re: Jamison boring rig - construction tips needed
Bill Clark
Answer - The rear support can be rather loose. All it does as act as a second rest. The top bar prevents disaster in case you get a bad catch. The bottom bar must be smooth and allow the "D" tool holder to move about easily.
IMPORTANT - Be sure you put some sort of removable stop on the back end of your "D" loop tool holder to prevent it from sliding forward out of the rear support. When you are hollowing your attention is on the cutting tip, not the rear of the long tool holder "D" loop. If you are cutting inside a hollow form and the "D" loop slides forward and drops out of the rear support your cutter will pivot up to the top of the inside of your hollow form and there will be a massive catch that will send your tool bar and holder (which is now free of the rear rest) flailing around. Your work will be in pieces all over your shop and you will be in the emergency room, if you are lucky.
Answer - A swing away bar could be helpful in some situations but not necessary unless you are doing some really deep hollowing and you can't mount the rear support in a position that will allow easy removal of your tool.
Answer - 3/4 inch is pretty much standard. CRS might vibrate a little more than a higher grade of steel. You will want a big diameter bar 1-1/8" (like Jamieson's Jumbo Bar) for really deep boring and some small tool bars for small entry holes. I use Don Pencil's scorpion and stinger tool bars on my Jamieson system. The length of the bars depends on your lathe bed length, how deep you intend to hollow and how far you can put the rear support rest off the back. Don't forget some method of holding your cutters at different angles and a swan neck or bent tool holder to accommodate wood removal under the lip or top of your hollow form.
Answer - You need a wide 9" or better yet 12" front tool rest. A OEM should work if the surface is smooth. It must allow the boring bar to slide easily.
Amswer - The more length you have the better your are able to insert the tool bar, tool holder and cutters into a hollow form of different shapes when working at the top of your hollow form. When you are undercutting around your entry hole and the top 1/3 of the hollow form with a bent tool holder or swan necked boring bar you need all the movement you can get. 38" should be OK. Remember to make the real tool rest with some way to rotate it in it mount to allow for easier positioning of your tool inside your work. A short rear captured tool holder will restrict you. The only way to get around it is to have a larger entry hole which you will not want to have as you skill increases. A small entry hole on a hollow form many times is the desired goal of a good turner.
Re: Jamison boring rig - construction tips needed-
Bill McWhirter
>Interested in a couple of the lasers. How much? How do I contact you?
Clyde Collier
>I would also like to have a couple of lasers
>You got excellent answers.
My situation is rather crowded. My lathe is against a wall (small shop blues theme playing here). You might look at curving the rest to get a little better swing if you are cramped for space.
I too might be interested in a laser or two. Give us some details.
Speaking of the laser, I would find a holder for it that had some sort of screw adjustments to move the dot in the X and Y axis' to be useful. Its easy enough, but why not. The laser that Lyle sold me with his had a lens for it that causes it to throw a circle. I may try to see if that is useful. Just put the circle around the tip and work with that.
Pete in Holland, MI
>Thanks for the insight guys.
I'll be working on figuring out what I have in my box of lasers and get them posted in the classifieds column soon. I'll leave a note on this Turning message board when they go up.
Pete
Eduardo sarmiento-hall
>Hi I have been using a sistem made by me from the plans of jammie,and this is my thing: make bars of diferents lengts and thiknesses,small vessels=1/2" medium=3/4" big vessels 1 to 1-1/4" bars the lengt is acording of the size pieces you be turning,bits 3/16 for small and medium bars ,1/4" fot the others,some times I use 3/8" I dont have a laser and dont need one I know when they are thin by noise or ligth I put inside the vessel when doing the outside,
In my case my bar slides barely in the holder so no to get any rattle,use shoe polish on the bars and tool rest and good turning
Jim Pugh, Elyria, OH
>Pete email so I have your address and I'll send some photos of a second iteration of the Jamieson jig. It is more compact and also more user friendly.
paul waddle
>I'd like a picture too and measurements. thks,pw
Do larger than 3/4" bars require different handle?
Pete in Holland, MI
>The plans I've found call for a socket in the handle for a 3/4" diameter bar. While I agree the bar needs to be larger in diameter as the length grows, do you simply turn down the tail end to fit the 3/4" socket, or is there a different socket needed?
Your experiences ?
Thanks !
James Ley
>I am also looking at building a deep hollowing rig. In my research I found this set of plans for a back tool rest. The plans are at the end of the pdf file.
http://www.woodturnerscatalog.com/woodturners/Images/pdfs/jamieson_system.pdf
Re: Jamison boring rig - construction tips needed *LINK*
Walter Ahlgrim
>1 You need the D handle to move freely. If you give the tool room to bounce around it will.
2 I have not found it necessary to unbolt mine but it could become necessary if you allowed the hollow form to fill with chips and they jamm the tool.
3 most � inch bars are 19 inches long. I think that is too long. At 19 inches your tool will vibrate but you can control it.
4 The tool rest should be softer than the tool. If not the tool be damaged and not move smoothly
5 Bigger is better I want more than 10 inches in front of the ways.
Do not try to stretch out this system build it as planed
Do not build a system with the front and rear tool rests are set at a fixed distance.
Do look at the Stubby boring bar system, it will fit most lathes, it allow you to choke up on the boring bar to limit vibration, no need to remove the tool to adjust the laser
Walta
http://www.stubbylatheusa.com/cgi-bin/index.py
Lyle Jamieson
Lyle Jamieson
>Hi Pete,
Great reading. Hundreds of people have made their own, or made parts and purchase the hard to machine parts. Most of your answers were correct.
There must be no binding with the handle in the back rest. Leave 1/16 inch gap. Mine are welded top to bottom rail. If you intend to build bigger and bigger tools to turn taller and taller vessels the back rest must be built strong enough th take the forces delivered. My Giant bar has a block bolted between the top and botton rails. The block will allow me to use my 1 1/2 inch giant bar and then turn the block 90 degrees and I can use my 3/4 inch handle with standard boring bars on the same back rest. The standard strength back rest would not carry the weight or stress from a larger hollowing system.
If your lathe is up against the wall, move it!! That position creats obsticles big time not only with hollow forms but bowls too. Obsticles drive me crazy. I want to open up posibilities not limit them.
Use cold rooled steel for the front tool rest. It needs to be softer than the boring bars. I use case hardened steel for my boring bars so they dont damage themselves. The stress on them is huge. A 3/4 inch bar will only get 11-12 inches dangle off into a vessel without vibration. But my bar is almost double that length, 20 inches. I think it needs to be longer to get the control I want to clean up tool marks. The shorter ones I have used seem to be herky-jerky feeling.
My back rest is 32 inches long and the pivot point on the lathe allows it to swivel/swing around to undercut any shape vessel you want. It can be longer but not shorter. The craft Supplies version of my backrest is too short. Many have complained to me about it.
Look at my dual purpose boring bar. You can reach any shape vessel with it and you only need to drill a couple holes in it for the swivel assembly. Otherwise you end up making or buying many boring bars to reach the shapes you will eventually want to create.
The swiveling cutter holder is essential. It will reach into the hard to reach spots you cant reach with dedicated cutters. And if you graduate to the Carbide cutter system the swivel is necessary to get the bevel supported cut in the right position to get the cleanest surface left behind you have ever seen.
Dont forget the laser, once you use it you will never go back to blind hollowing. The "dot" of the laser is not an issue. It is the gap between the cutter and laser that gives you the accuracy. The X-Y slide idea seems cool at first thought, but in real life it will drive you crazy. The laser has to be moved often to follow the surface contour of the hollow form. The laser holder needs to be moveable easy and quick and accurately yet stay where it is set when hollowing. The X-Y only gets you accuracy. I have the right lasers for $20.00.
Before you build it check out my DVD from your clubs library to see the set up process and the use techniques. Most of the copycat systems out there have made systems with good intentions, but most have obsticles built into their design. Dont over engineer it, keep it simple. It has to work good...not look good.
Lyle Jamieson
Lyle Jamieson
Lyle Jamieson
>Pete,
OOPS! I just noticed you are in Michigan. Come up to Traverse City and Ill show you the real thing and help you with the details. Lyle
Pete in Holland, MI
>Hey Lyle -
Thanks for the insight.
I have pretty much been self taught in my turning these past few years, sort of a couple evenings with a bowl turning friend. Have been thinking about some professional training. Probably should do it while I am still surrounded by snow & can't play outside anyway. Will approach this opportunity some time in the future.
Pete
Do it.
Steven Kubien
>Pete I had the opportunity to be part of a small hands-on class with Lyle back in Feb of last year. I learned tons. Get some snow-tires and head to his place. You won't regret it.
Steve Kubien
-no affiliation blah, just happy dude blah blah
Dick Hines
Dick Hines
>There is Lyle be a class act again. How many people do you know that make part of their living selling a product and then have them agree to help someone make one of there own instead of buying one form him.
Peter Lamb, in SC
Peter Lamb, in SC
>I could not agree more with Dick's view of Lyle.
Thank you Lyle!!
Paul Waddle
>Lyle is a fine gent. I scratched a dvd I bought from him, and he replaced it. I'm gonna make a boring set up as he suggests,but want to buy the cutters and and an adjustable(?) tool holder that will allow me to set the cutter at angle to reach the part close to the neck on small fat vessels.pw
Pete in Holland, MI
>Thanks for all the insight guys! I will be puttering with my jig for the next couple weeks. Keep you posted on what I learn and any revelations along the way.
Pete
