vacuum chuck adapter
David Haywood------WebKitFormBoundary+AxzTe6sNdr8l
>Does anyone have an easy, quick, foolproof method of building a homemade vacuum adapter to fit a PM 3520B lathe? All my attempts to this point have either leaked or stopped the rotation of the bearing.
Re: vacuum chuck adapter
Pete in Holland, MI
>My swivel was built in my shop. Proper sealed (not shielded) bearing is critical. Clamp on the bearing with your lips, plug the hole with your finger, and suck. This was my test (had access to various surplus bearings). My bearing chosen had a good seal and has probably 15 hours on it thus far.
Keep looking. They're out there.
>Dave,
after several failures I bought the Easy Vac unit and never looked back, it works great; not home made, but it let me turn platters and such in a short time.
Jorge
Fog Tanner
>I made one from an article I found either in the WC articles section or on the net. I think it was Al Crandall that wrote it. All the parts are either hardware store or from Lowes. I made one, but my brother in law came up with something better.
I have a 1" thick Nylatron "wheel" that bolts to the hand wheel on my Vic. The Vic hand wheel is flat has four holes which was convient for this. The Nylatron wheel has a Delron insert for the bearing. A brass bushing was machined down and pressed into the bearing. This allows me to use a 90 fitting with a hose barb and hose to connect to the vacum manifold. It is easy and quick to install or remove. It has no leaks and I am pulling 26" through the spindle. I like this better than any of the other adapters I have seen. My brother in law is a machinst and not a woodtuner, sometimes we get better ideas from outside the box.
Fog
