Oneway chuck
Bob Moffett
>I have Oneway chucks, both Stronghold and Talon, and am having trouble opening and closing the jaws. What would ya'll remoccend to use to clean the chucks so they will open and close better.
Oneway chuck
Bob Moffett
Re: Oneway chuck
Ron McKinley
>I blow them out with compressed air and then spray them with a silicone spray. Silicone does not attract dust like WD-40 does. Even if you use a lacquer finish the silicone is behind your piece and will not interfere with the finish......Ron
Re: Oneway chuck
Fog Tanner
>I have two Strongholds and I do the same as Ron, except I use a dry Teflon spray. A little compressed air every so often seems to keep them operating well enough, and the Teflon when they still seem a little stiff. I have not had any sticking problems with my Vics, but would do the same if I did.
Fog
Re: Oneway chuck
>Bob,
I've disassembled chucks for a more complete cleaning. I have Supernova instead of Oneway but I suspect your's can be disassembled as well. I like to lubricate internally with a dry film spray to minimize fine dust accumulation.
If you disassemble the chuck, you can also check to make sure the jaw slides are not binding. I say this because I once bought some chucks that were very tight. I found they had been overstressed which caused binding. Some rework made them good as new.
Vicmarc chucks
>I have 3 of them and so far haven't had any problems. One time one did start to stick, I just barely blew it out with the compressor and it stopped. I suspect a chip of some sort because it took so litte air to clean it up.
I was wondering if anyone had problems with these. When I bought mine I was concerned that it would be hard to clean because they have a backing plate that has index holes. So for they haven't needed cleaning but then I'm sure there are people out there who use them more than I do.
Re: Oneway chuck *LINK*
Rick Allen
>The Oneway Stronghold manual says:
"To clean your chuck, simply brush clean. If it is sticky, soak in varsol or mineral spirits with about 10% oil added. Allow to sit for 1/2 hour or more, and blow clean."
If you don't have a manual then you can download it from Oneway. Page 10 and 11 talk about chuck maintenance.
Oneway Stronghold Manual
Re: Vicmarc chucks
Donna Banfield
>John, all my chucks are Vicmarc, and one I've been using since 2002.
The bright shiny finish ain't bright and shiny anymore, but it still opens and closes as smooth as the first day I used it. I've never taken the Vics apart, but do blow them out with compressed air.
Re: Oneway chuck
Norm Koerner
>Instead of using a solvent with 10 percent oil added, just soak the chuck in good old KEROSENE. Kerosene itself is a very, very light oil.
Re: Vicmarc chucks
>Mine aren't shiny either although I have one of the Grizzly's and it is rustier. Apparently it doesn't have the quality of finish of the Vic,s, imagine that. :)
Re: Vicmarc chucks
Fog Tanner
>I have four Vic chucks, which are what I use most of the time. I have not had any problems with them and they see a lot of dust. I do have the rust problem on the large 5 1/2" , but so far the 3 1/2" haven't developed that issue.
I have the new Vicmarc Escoulen chuck, which is different that the other chucks with builtin counter weights and an offcentering mechanism. It appears to be plated, it has not developed any "spots". I am not sure if they are plating all their chucks now, but it would be a good move. I am thinking about disassembling the 5 1/2" and blueing the body it with some cold blueing or hot browning solution. If I go the browning solution (which I like better than blueing), I will use the hot wax patina method same as I did on my gun barrel.
Fog
Re: Oneway chuck
Bob Moffett
>Thanks for the good advice everyone. I knew I could count on the good people at WoodCentral.
Re: Oneway chuck
Russ Fairfield
>Liquid Wrench is a good lubricant for chucks and other moving things. It doesn't collect dust, it doesn't interfere with any finishes, and it doesn't get gummy with age. Just squirt it on, work it in, and blow off the excess.
