MDF
MDF
MDF
Steven Smith
>Is it safe to use MDF mounted to a face plate as a jam chuck? thanks in advance.
Re: MDF
Re: MDF
Texian
>Probably ok for some projects, but I prefer ordinary SYP construction lumber. Freebee scraps are usually available from building sites.
Re: MDF
Steven Antonucci
Yeah, but...
Steve Antonucci
>I've turned MDF before and it makes a huge mess and dulls your tools like nothing I've ever seen (think it's the glue...)
Nice thing about it is that it doesn't move with the seasons, so if you suffer through it, it'll last forever.
Steve
Re: MDF
Re: Yeah, but...
>I would not use it for anything with any weight. It gives way and does so very quickly. For small turnings it's fine. For bowls and hollow vessels I prefer to use solid wood that has reasonably straight grain. I do use pine 2x4's occasionally for smaller stuff but prefer harder woods like yellow poplar or maple.
Re: MDF
Re: MDF
Rick Allen
>Yes MDF is safe to use mounted to a faceplate as a jam chuck.
Mounting "stuff" to MDF without tail stock support is not recommended.
Re: MDF
Dick Hines
Re: Yeah, but...
Dick Hines
>I use MDF as a jam chuck. I don't turn the MDF in the shape of the inside of the bowl though. I put a face plate on the MDF and trued it up. Then coated the MDF and a sheet of cork with contact cement. Put the togerher and let dry. Then all you have to do is use your tail stock to hold the bowl to the cork ant turn off the foot.
The cork will keep the piece from slipping and wil not mess up your rim. The cork is easy to replace too.
Re: MDF
Re: Yeah, but...
Bob Macgregor
>Would self-adhesive Foamy sheets give similar traction?
Re: MDF
Dick Hines
Re: Yeah, but...
Dick Hines
>I expect it would. a friend of mine has been useing the MDF and cork system for years. I figure if it is good enough for him it good enough for me. And I am to cheap to buy a vacuum system.
Re: MDF
Re: A lass Poor Yeah, but...I knew him well
Dave Anderson (PacNW)
