Plastic Spindle Washers
Ed Conhaim
>Am turning on a Jet 1236 and sometimes either a faceplate or chuck does not want to unscrew from the headstock spindle. I have been freeing them when this happens with a good sized pair of waterpump pliers but that is leaving teeth marks on the faceplates. Have read somewhere that there are thin plastic washers that go over the spindle that eliminates this problem. Anyone have any experience with this and if so, where can these washers be purchased? Thanks for any help.
Re: Plastic Spindle Washers
Rob Wallace
Re: Plastic Spindle Washers *LINK*
Rob Wallace
>Spindle washers made of nylon or delrin/acetal can be bought from turning suppliers like Craft Supplies of Packard Woodworks. (You'd need a 1" washer for the 1236). They are about $ 2 each, or less if bought in quantity. See the link below...
I have known some turners to make their own washers from one or two layers of plastic cut from the side of a discarded plastic milk jug. Probably won't last as long as thicker washers you'd have to buy, but the price is right...
Rob Wallace
Spindle Washers at Craft Supplies
Wally Dickerman in Arizona
>I suggest that you don't need or want plastic washers. You get a more solid cut if the faceplate or chuck is firmly seated against the spindle. If you have problems removing stuck faceplates it's because the faceplate/chuck wasn't seated firmly. If there is any slack at all, when the lathe is turned on, the slight movement of the faceplate freezes it on.
Wally
GalenV
>I had a bigger problem with the metal lathe I had but found the simple solution back then was a very small amount of anti sieze compound on the face of the spindle or apply to back mating face of face plate or chuck. This was enough to prevent galling of the less machined surfaces. They always seemed to get nicks over time that made galliing worse. It was never in the threads.
I learned, like Rob noted, on my wood lathe to use a plastic washer. It prevents the gum mess I would have with dust and anti sieze.
I used plastic from whipped margerine lid and later bought the nylon or delrin. To be honest I went back to my home made and the purchased one is in my lathe accessory box.
Galen
>I've been using air tool oil to lubricate the chuck and spindle. I apply some and then wipe it all off. I leaves a little residue that doesn't seem to attract dust but my chucks never lock up on the spindle. I think it was Steve Russel who suggested that.
Before I started doing that I made some washers out of milk jug sides and then I bought the commercial ones from Craft Supplies.
Like Wally I prefer to do without them but I have one faceplate that just want's to lock up. I'm not sure why, so I use the washers with that one.
Fog Tanner
>I am with Wally on this one. The plastic washers can have enough "give" to allow vibration on heavier out of balance pieces.
I had the problem of chucks and faceplates being difficult to get off after use. Like everyone else I was "snapping" the chuck/faceplate onto the spindle shoulder. I started screwing the chuck/faceplate up the shoulder, making sure that there was contact and have not had the problem since.
On my Delta there is a relief cut on the spindle for a set screw used on some of the chucks (Stronghold). On my Vic, there is a "retaining collar" which I can use with the Vic chucks to lock the chuck/faceplate in place. I use each occasionlly, but for the most part have not had problems with blanks unscrewing. I also have the electronic braking turned off. The braking can be a problem on large blanks and cause them to unscrew. I do use the handwheel as a brake and can slow the spindle down without the chucks unscrewing and still unscrew the chuck very easily.
Fog
Dick Hines
Dick Hines
>I broke my spindle lock trying to get a big chuck off my PM. I tried pipe wrench but did not like the marks it left on the spindle.
Lately I have been useing a piece of browm paper bag with a light weight oil soaked in. . I just put the oil on the bag. I have not had any trouble getting the chuck off since.
You will have to clean your spindle when you take the chuck/face plate off though.
Ed Conhaim
>Thanks for all the information.
Bill Grumbine - Kutztown PA
>I agree with Wally here too. I tried one of those commercial washers, and all of a sudden my work was suffering from vibration. I took the washer off, and the vibration went away. So the washer went away too.
Chicago Bob
>I like Dick's brown paper bag/oil homemade washer instead of trying to deform a purchased nylon washer. It is thin enough to result in a tight, vibration free conection, very cheap vs $2 plastic washers and the spindle frees quite readily without using damaging pliars..
If you don't want to fool with paper bags and have a little change to spare, oil soaked fiber washers work as well.
Regards & thanks for the excellent information always available on this board
Bob Haines
Ed Heuslein
>I too have discarded my plastic washers. They seem to add to the "off center" problem when re-chucking. I can't recall of any internationally known turners who use them. I've found that cleaning both mating surfaces with a soft rag and just tightening them down carefully, not spinning them tight, works fine.
Try a paper washer
Ron in Drums PA
>No vibration and face plates don't lock up.
