>The Beall Tool web site only says the smaller 2", 3", and 4" bowl buffs should be run at a higher speed than 1725rpm. It does not indicate what size is best suited for bowl inside diameters.
On my 1220 Jet I only turn 7 to 11 inch diameter bowls.
Would the 3" be the best size and what speed to run?
The 2" would seem to need to run faster and the buff is not much bigger that the hub so seems like you might clip it while buffing.
The 4" may be too big but would maybe run slower. Not sure if it would be harder to control in small bowls.
>Galen I use the 4" wheels for everything and run them about 1000 rpm. The work just fine. If I need a stiffer wheel to reach into some area I crank the rpm up. You can of course slow it down to wrap around some areas. I personally don't think speed is needed. I do crank the speed up for the Carnauba wax. It is quite hard and needs more speed to melt in.
I've thought about talking to Jerry Beall to see if he'd consider making and selling 6" buffing wheels - I have both the 4" and "standard" 8" wheel sets, and there are times I'd like to use a wheel in-between these sizes. I suppose I could cut down an 8" wheel to 6", but it would be a heckuva lot easier to just buy them all ready to go...
I wonder how many other turners would be interested in 6" Beall buffing wheels?
>I ask the question as I was given the Beall 8" wheels as a gift and made the outside of my bowls looked better than the inside. I was thinking of getting the round bowl buffs for that.
Sounds like maybe the 4" wheels are being used. They are cheaper set than the round ball buffs anyway.
I realize Beall is probably just adding hardware and the adapter to make his kits. I have other buffing wheels and balls but all are contaminated from use on metal polishing. If I purchase his it gets me three types of wheel materials and hardware to match adapter I got.
