Feathered Bowl
Dick Hines
>This is something that took most of sat to finish. It took longer to set up the grid and burn than it did to turn and sand.
I used one on Molly's home made burning pens.
Cherry 3"x7"
Feathered Bowl
Dick Hines
Cherry 3"x7"
Re: Feathered Bowl
Carole Valentine
>Uh oh! Dick's got the burning bug!
Question for you...why lay out a grid on the piece? Just use your indexer to put reference points top and bottom for each feather, draw one perfect one on transfer paper and then transfer the outline of the feathers to your workpiece by lining up the drawn one on transfer paper with the reference points? Seems like that would be a little easier when you have duplicates all the way around the workpiece.
Re: Feathered Bowl
Dick Hines
>Well I did the grid so I would not screw up and burn the wrong place. The steps in the feathers were giveing me trouble so I used my indexer and set up a grid to keep me on track.
Working an a holly bowl now that is going to have some more burning. I am hoping it will be more complex than the feathers.
Re: Feathered Bowl
John Scheideman
>That's really nice. I like the texture of the burned area. Nice work!
Re: Feathered Bowl
Cyril Griesbach
>Really nice, Dick. I've been looking at Index systems because the process on the PM3520B is a real PITA.
Re: Feathered Bowl
Dick Hines
>The one I have fits behind the chuck or face plate. Go to the Mustard Monster page. I think that is where I found the company. I will check and let you know.
Re: Feathered Bowl
Dick Hines
>Check out www.alisan.com
