Using HF drill vise to bore on wood lathe
Paul Waddle
>I know there are of turners out there with HF drill vises. They can be used on 10" and larger lathes to bore a little more accurately than by hand. The problem comes in that you want to use the cross feed in a "longitudinal" direction to get more depth, but can't because of the handle hitting the lathe bed-especially on a smaller 10" lathe. I had an idea and it works. Remove the handle,jamm two nuts together so they won't back off. Now get a 1/4"drive socket to fit the nuts and universal joint and palm handle,you'll be able to turn the vise(boring tool) without hitting the lathe bed. If you can afford a used rockwell compound for 275$,disregard,this is for us retired po folk. Bolting the vise to the lathe can be a bit of a challenge on the 10"er, but on larger lathes a ply wood plate can be used. pw
Re: Using HF drill vise to bore on wood lathe
>Paul You can also buy crossfeeds with much longer beds from Enco and others that run about $80. You have to supply your own vice but that is one of the best purchases I've made. I use it on my drill press and have used it on the lathe a few times. I haven't attached my router to it yet but you know that's coming.
Re: Here is the one I have.
Paul Waddle
>That's a good 'un John! I have been toying with the ideal of making an inexpensive compound,one that turns several degrees and has a feed that goes in line. Some folks think you can just angle cutter and feed with a HF or other vise-that won't work,you'll just scoop out hollow. ha ha Wonder if the following will work: make a swevile cradle that will hold a Sears vise. Through the fixed jaw,bore a close fitting 1/2" hole. On the moveable jaw attach the boring bar. Insert this rig in a drill press vise. Now the end of the boring bar can be drilled and fitted with other tips....Should work... pw
