ANy tips on green holly ? ?
Chuck Engstrom
>Hi all -- I've been given some nice freshly cut holly of about 12-15 inches and would be grateful for any tips on getting best results from it.
Thanks--
Chuck Engstrom
Chuck Engstrom
Thanks--
Chuck Engstrom
Re: ANy tips on green holly ? ?
Carole Valentine
>Chuck, search the archives...there are tons of threads on working with/preserving Holly.
>Chuck,
As she said, there is previous information. I asked this question just a few weeks ago and got a lot of good information. I think that thread was named something like "keeping holly white".
With that and from other research I've tentatively concluded: 1) There are at least two different processes that discolor holly - a chemical/mineral process and a fungus. 2) There are several types of holly and holly grows under various conditions which may make specific pieces behave differently. 3) There may be nothing you can do to insure a particular piece stays white. 4) Even if holly changes color, it can be bleached back to pure white before finishing.
I've cut up holly twice into turning blanks. The first time it all stayed pure white. The last time, some pieces seem to be developing a greenish internal cast. I'm air drying some slowly in a cool area and others in my "kiln" (leaning against the wall behind the woodburning stove) to see if there is any difference.
Carole Valentine
>John, I will have to disagree with #4. In my experience, some of it will NOT bleach back to pure white...no matter how many times you bleach it.
Ken
>I cut a bunch of holly a few yrs ago in NC, it will not only give you a bath while turning it green,but will split just looking at it.I learned that leason the hard way,plus it will move all to Hell.Yr before last I rough turned about 20 bowls,around 8" 3/4 thick, sealed the endgrain then put in paper bags with chips.Came home to Tampa for the winter and when I went back up there last yr ,they had warped so bad that I was only able to save about four of them.I then was told by another turner up there that turns a lot of it,that when he cuts the logs,all he does is seal the ends and will leave them set for at least a yr before cutting blanks and since doing it this way he hasn't lost any pieces.So now I'm letting it set.As for keeping it white,according to him,there is no guaranty that anything will work all the time.
Thanks. That came from two others who have done it, but as said, there seem to be different types of discoloration. Perhaps bleaching will whiten a fungal but not a mineral stain.
Thanks very much, everyone --
Chuck Engstrom
