>I had a busy weekend. I had a new potential turner come over Saturday morning. He's coming over next weekend for a class. Nice guy. He is a nationally known photographer so we hit it off pretty quick.
I turned 5 short finials that are replacements for an antique clock. I still have a few more applications of stain to get the color right on the 3 tall ones.
I made the tool for one of our club turners. It's a 5/8" bar with a 5/16" cutter in the tip.
I'm behind on my mirrors so I turned a quick on. I've got to get another dozen done pretty soon so I'll have to fit those in as I can.
the bottom metal piece is a tool I made to quickly produce #2 morse tapers in wood. This was taken from John K's drawing that he produced a few weeks ago.
>I made the tool John K Jordan drew up a few weeks ago. It's 2" long. Make marks on your spindle 2 " apart. Then use a parting tool cut in at these 2 points using either end of the tool as a depth gauge. Connect these with a skew and you have a #2 morse taper in wood. Very handy for a lot of situations.
>Great! In case anyone is interested and missed it, here's a rendering I posted before of the sequence I use to cut these jam tapers.
I usually cut a little relief in the center of the taper with the parting tool as the last step - this can give a tighter fit if I'm a little sloppy in cutting the taper.
>JKJ : I presume that the right hand end of the jig is the small end of the taper and the left hand end of the examples are the small end. What is the total length of the samples ? Can you supply measurements for the two yolks ?
>Bill I measure 2" apart which is why my gauge is 2" long. I simply lay the gauge on the wood and make 2 marks. Then use the parting tool at these 2 points. I make the taper a little longer than this but it's not necessary. John's idea of cutting a slight relief in the middle is good, especially if your not that good at cutting straight lines.
It doesn't have to be perfect. Wood compresses so when you drive it in the taper it usually fits unless it's really off.
>I like the finials and the boring tool . I should think a lathe compound on the wood lathe would be a better way of making a morse taper,using your guage to mark the large and small od.pw
>Thanks, John. I will try it. I have been making my Morse tapers with a jig made from a couple of pieces of Oak fitted to a handle that diverged in the same dimension that the Morse taper diverges, but it is not always a good fit.
Yes, the left of the samples are the small ends. I could measure my gauge but you'd probably be better off measuring yourself. While the taper is well defined for MT2, I don't know if the diameter at the opening of the spindle is the same for all lathes. If your's was larger, my gauge would make a taper that might fit too deeply. FWIW, it was the same on my two lathes.
I measured an MT2 drive center that had been used in the lathe so I could see from the burnished marks exactly where it fit into the spindle. Then I measured the diameter some arbitrary distance back from the first mark for the small end of the gauge. I made a little mark for this distance on the side of my gauge, I think it was about 1/2". I didn't check, but thinking about it now perhaps the diameter of the gauge at the small end would be a good separation if it wasn't too long.
I also cut a small "lead-in" relief on my gauge as a sort of warning to slow down the cut when I was just about to the correct diameter. BTW, I cut my gauge out of a piece of brass using my bandsaw. I made the diameters a little bit tight then filed the sides until it fit perfectly over the correct spots on the taper.
I use the morse taper jam chuck method on every one of the hundreds of wands I turn and often on finials and things as well. After you do a few, it only takes a few seconds to cut one.
I the Lucas gauge might look better than mine. The rendering was of a 3D model so it could be perfect!
>What if.... after using John's(K or L) guage to mark the two dimensions,bring the tool post up and use a pattern(ply wood or brass )that has the correct taper-maybe use a center. Align the tool post to this angle and rub the tool post... pw
>but it seems a lot of trouble when in only takes about a minute or less to mark it off and cut it. I used this method for my students to turn ornament finials. The lathes and chucks we had would not accept small wood so e-mailed Mark St.leger and asked about his wooden more taper experience since he's the first one I saw do this. All of the student's were able to do this successfully which tells you that it's pretty easy since some have never turned before. I had the newbie's use a flat scraper if they had trouble with the skew.
