Need a Quick Answer
Barbara Gill, Remlik VA
>Our daughter is at Woodcraft and is looking at a VS 1236 Jet lathe that has been used for classes. It is on sale for $ Is this a good deal$500?
Need a Quick Answer
Re: Need a Quick Answer
Wally Dickerman in Arizona
>Not in my opinion Barb. I've turned on the 1236 a few time and don't like it. I may be in trouble with a few folks for that answer. Unless long spindles are on her mind, I would prefer the new 1220 Jet at about the same price.
Wally
Lan Brady
>I am a Jet Lathe user. I agree with Wally. Better to buy the new 1220. If you are turning spindles, get the bed extension.
Lan
>Well, she bought it because someone came in and wanted to buy it right from under her and even offered more money. Thanks for the quick replies though.
Now I need to pack her tools and grinder to send to FL.
Well, Since She Bought It
>My suggestion to her was not to mess with the swiveling head. Is there a instability problem with the 1236? If so I will suggest using some bags of Sancrete or sand.
Greg Haugen
>Sand Bags would be a good idea no matter the lathe-weight is our friend. Swiveling of the headstock for "outboard" turning, I'd say absolutely not. Since the headstock doesn't slide though, I do like the option of tipping out the headstock, say a 45 degree angle, so I don't have to reach over the lathe for hollowing by hand. Easier on the back and as long as the size of the piece is within reason, it's safe. Rough and shape the piece in the standard configuration, then tip it out for hollowing. One nice thing about the captured systems available today is that they're alot on easier on the back and no twisting or leaning required.
Also, keep the reeves drive maintained well. That's the key to those systems.
just my 2 cents...
Greg
>Thank you Greg. My first lathe was a Nova 3000 many, many years ago. I used to swivel the head without problem with stability (the lathe with weight added was 1000#) but sometimes there was an issue with getting it back exactly in line. Before I bought the Oneway I decided to stop even turning the head slightly outboard and was much happier.
Re: Well, Since She Bought It
Lan Brady
>Barbara,
Although I prefer the 1220, The 1236 is a good machine. I do like Jet products. The added weight is a big improvement on the machine.
When you swiivel the headstock and want to realign, just put in a drive spur and a live center, Point to point and it will work well.
Good Luck to your daughter, Lan
Ken
>Good luck to her,hope it gives her many yrs of good service.Where in Fl is she.Tampa here and I go to the woodcraft in Clearwater.
>She is in Jacksonville.
>Thanks Lan.
You know I usually don't do much spindle turning but I really appreciate the length of the bed of my 1640. You never know when you might need the capacity for spindle work.
Barry Elder
>Barbara, I have used a 1236 since the hurricanes of 2004, and while she will need to add weight to cut down on the vibration of unbalanced blanks, and she will need to do regular maintenance on the reeves drive system, a good bandsaw will help her more than anything else to get good use out of her overpriced lathe. IIRC, I paid Amazon somewhere around $300. new and free shipping. The only reason WMH has for raising the price on this lathe is shipping from China. No improvements have been made to warrant a list price of $750. I hope she is talented and fortunate and makes some of the naysayers look again.
>Thanks Barry; I have let her know. She does not have a bandsaw however I think there might be a number of Flat Rate boxes of wood going South soon.
Bill Blasic
>Barbara,
Packard sell a double ended Morse Taper Alignment tool that makes bringing everything back into alignment very easy and it is not very expensive.
Gordon Seto
>Woodcraft has a 90 days satisfaction guarantee. IMO, it is better to trade up for a Jet 1220VS. Woodcraft is making a sale on the new lathe; she is not taking advantage of their policy. $500 for a used 1236 is no bargain at all. Woodcraft knows that.
That was my first lathe. It was an OK lathe, I upgraded to a Jet mini 1014 VS. The new generation of Jet runs smoother; performs better within its capacity. The Reeves drive is high maintenance; the speed can only be changed when the lathe is running.
The 1220VS has the minimum speed of 200, which is more suitable for turning slightly off balance bowls.
Don wilcut
>Emory Mclaughlin
3648 Coronado Rd
Jacksonville, Florida 32217
904-730-6018
Excellent turner and instructor in Jacksonville. I've seen him several times at the Flordia Symposium.
Don
Greg Haugen
>I'd recommend to her to buy a "double ended" morse taper. I think Packard sells them. One end is placed in the tailstock and the other is placed in the headstock. The two will be "in line". It's alot easier and faster than lining up the centers' points.
Tell her to have fun, that's the main goal. :-))
Greg
Philip Morris
>Barb,
I concur with Gordon. This is really a marginal lathe. I had one for a brief time. Even after attaching 3/4" plywood sheets to both ends of the stand with double faced foam tape and then bolting it, adding a cross brace of 1 1/2" angle iron to tie the ends together and attaching a shelf with 300 pounds of gravel, it vibrated more than my 1220vs with the same out of balance blank.
If she can return it and buy a 1220vs, she will have a much better base from which to learn.
Bill Bulloch
>The adding of weight to the 1236 cannot be over emphasized. With my first attempt at turning the head, the machine vibrated so hard that it broke the motor mount before I could get it turned off (about 5 seconds). Unfortunately the motor mount is part of the motor and the whole motor had to be replaced. Fortunately, when I called Jet they understood the problem and sent me a replacement motor within a week.
Dick Hines
>Barbara, it looks like you are starting to infect the whole family. I guess Dan is next.
Bob Macgregor
>My daughter is in Ocala, but not turning. If you think woodturning is an expensive addiction, try (horse) eventing. For what we spend on her horse habit, I could replace my lathe with a new one every month and still have money left over for all the tools I covet!
BOB
bill Crommett
>Leave Dan out of it. Let him do his cooking thing .
Actually
>Dan did some spindle turning before I ever started. Sarah turned a holder for a pepper mill when she was just a kid. Shelley stated turning a little when she was at Lackland AFB many years ago. I think I am the late comer.
There is a Saying
>that a boat is a hole in the water into which you throw money. I think a horse is an appropriate substitute for landlubbers. :-)
Thanks Everyone For All The Help
