>Not the most artistic example, but this Magic Sceptor (sounds more artsy than magic wand), is a Proof Of Concept (translucent turning with internal lighting source) piece. Might be an idea for the folks doing ornamental turnings in acrylics or segmented turnings which include acrylic areas as well as alabaster turners.
>Son's been bugging me for Harry Potter's wand and daughter wants Hermione. 20 seconds of turning each with 4 hours of carving... so wht not add another hour rigging a glowing mystical tip?
Re: Example: Translucent Turning w Internal Light *LINK*
charlie belden
>I picked up the LiteStik (#3 in the first picture on the attahced web page) at what used to be called a Five and Dime store - all sorts of stuff for a buck to about five bucks. They're putting little battery powered LEDs in all sorts of things and they seem to be everywhere, 7-11s, drug stores, hardware stores, etc.. The "clip on the visor of your cap" 5 LED (#1 in the photo) is pretty bright and it was only $3.
Legend65 over in the usenet newsgroup suggested an interesting idea, use a small ball end bur to carve the INSIDE of the piece to thin the walls but not pierce them - and create glowing areas on an otherwise opaque piece.
An internal light source opens up lots of interesting possibilities, and in the right hands - and mind - could lead to some nice, unusual, pieces.
I tend to get a Wild Hare Idea, take it to the point where I make a Proof Of Concept piece or two - then get distracted by another Off The Wall Idea and never really refine the previous idea (incorpoprating a ball and socket joint to add movement to a piece, using parts connected with small spring steel wires to add movement, making a little turned hollow form into a two or three note flute when a knot falls out, etc.).
I've got one piece to finish that uses the Internal Lighting Idea - and then I'm onto exploring using parts of turned pieces to make jewelry.
There are so MANY turning paths to explore - which is why I enjoy the journey so much.
>I thought it was "just me!" I scan the after holiday sales for cheap LED "stuff." You can get some really good bargains. I got a string of battery powered LED's for $0.99 at Walgreens. I've used some things like that for lighting holiday manger scenes and such. The outdoor solar powered flicker lights (look amazingly like a candle) can be used for all sorts of things too. Target had some nice battery powered flicker candles for $9.99 normal price this year. Didn't catch those on sale. Maybe next year.
