It�s a disappointment when �
Rich Pearson in Mill Creek, WA
>A bowl �turns� on you! I made this segmented bowl (I�m a beginner .. it�s my 9th turned piece ) using standard procedures. About three weeks after completion, the base cracked. As you can see in the PICs, there are two radial cracks, joined by a crescent crack around the plug in the center. The cracks are thinner than a credit card.
The dry fit looked perfect .. no light was visible between any joints. I glued up the base in halves and flattened the diameters before gluing the two halves together. I bored a hole for the plug, turned the plug to fit and glued it in. I use Titebond II glue ( using the last of a gallon jug which was about 2 years old). My shop temperature is never below 58 degrees and is warmer when I am gluing and turning. I used Tried and True oil to finish the bowl.
My other bowls, made using the same materials, glue and techniques have held together just fine. The woods used have been in my dehumidified basement shop for over 6 months.
Any thoughts as to what�s going on??
I have trashed the glue and will part off the base and glue up another one but I�d like to avoid this problem!
Any input/experience you can share will be greatly appreciated.
Thanks
