Electro-Forming Over Turned Piece
charlie belden
>Steve A.'s "Meteorite" piece, which is an interesting idea, got me thinking back to my jewerly making days. I used to do mainly lost wax cast pieces, but got a bit into electro-forming in order to do larger pieces - without the weight normally associated with larger volumes and surface areas.
Basically, you electro-plate onto your model - in my case wax, but I also did this with wood - but deposit much more metal onto the surface - enough to actually have some structural strength after the model is removed - in my pieces it was melted or burned out. The resulting thick "skin" can then be polished and/or patinaed.
Since the current trend in turning is to start with a turning as the basic canvas, then either do surface treatments or piercing - the turning is only the base on which the fun stuff is built. Japanese lacquer ware is a great example of the "the turner's work is merely the canvas upon which the valued lacquer work is done" approach.
Now if the goal is to create an interesting - turned - 3D object, electro-forming may be an interesting area to explore. Since the "core" on which the electro-formed piece is to be developed - and only on the outside surface of the turning - NO hollowing is required - since the "core" will be removed from the final piece.
Now I know you're thinking "OK - so how do you remove the core - of a 'hollow form'? Sure, wood burns - but . . ."
Think WAX. There are waxes you CAN turn. AND, if you make a mistake - you can melt some new wax on the OOPS. AND - you can ADD wax to the piece, anywhere you want to! AND, when you apply a conductive paint to the surface for electro-forming, you'll only get metal deposited - where the paint is. No piercing required - metal where YOU want it.
Want a nodular, bumpy "organic" surface? Electro-form relatively fast. Want a smooth surface? Electro-form very slowly, smoothing out imperfections after the basic forming is done - and re-eletro-form to the wall thickness you want.
The electro-forming set up doesn't have to be all that complicated - or expensive. You need a DC power source (battery or battery charger), some copper sulfate (available at hardware stores), some copper tubing, pipe and fittings, some copper wire, a few pieces of copper bar or sheet - and some dilute acid - dilute sulfuric preferable.
The attached image illustrates the basic idea.
Oh, and you might want to pick up some powdered gelatin. Dissolving the gelatin in the "electro-forming" solution increases its "throwing power"
Plating is basically a Line of Sight - from the positive Anode (copper bar or sheet) to the negative Cathode (your surface conductive piece). By placing multiple Anodes around your piece, space about equidistant to the piece's surface, you'll get a fairly uniform deposit of metal on your piece. Normally though, the close an Anode is to the piece, the more metal you'll deposit to that surface - high points on the piece will "grow" faster than low points. That's a "current density" thing. That's where the gelatin comes in. I'm not sure how or why it works, but gelatin dissolved in the solution reduces this "lots on high spots, none on low spots" problems.
How'd you like to do pieces with wall thicknesses of 1/32nd or 1/164th inches? And wouldn't it be nice to be able to ADD feet, or sculptural shapes to the surface, rather than having to REMOVE material to get them?
AND - if you melt the core carefully - you can resuse the wax.
Yet ANOTHER turning as a starting point path to explore - or not.
Just something to consider.
Re: Electro-Forming Over Turned Piece
Steven Antonucci
A lot easier to paint with metal based paint :-)
Steve Antonucci
