use of a laser for hollowing
joe zarnitz
>is a laser that much better or easier to use than to measure with bent wires or other means----does it stay in adjustment or does it need constant checking-----tks,joe
joe zarnitz
Re: use of a laser for hollowing
robo hippy
>It does need slight adjustments depending on where you are cutting, more if you have a shoulder, and less on a straighter form. It has to be at 180 degrees to the cutter. For me, it is a minor inconvenience compared to the calipers.
robo hippy
>You do need to adjust it frequently although you can learn to turn one area, adjust the lazar and then move on to the next. It doesn't really need to be moved constantly. What I do is to set the lazar near the point of the cutter. I do most of the hollowing this way without adjusting it. I find it much faster and less nerve wracking. Bear in mind that I don't do a lot of larger hollow vessels so each one is a little interesting for me. Once I have the bulk of the wood removed I set the lazar for the thickness I want and perpendicular to the cut I'm doing. This is slower but I've had good success with it.
I use the bent wires on smaller vessels simply because I'm more comfortable turning these vessels. On the smaller ones I tend to use my armbrace or simple hollowing tools instead of the captured bar system.
Just for fun I used the lazar on christmas ornaments one time. I could make them pretty thin and more consistent with this but it was slower than my other methods.
so I think a lazar and captured bar has it's place. If you turn a lot of hollow vessels you are probably good enough to do without one. David Ellsworth and John Jordan have done it for years. If you only occasionally turn hollow vessels I think the lazar and captured bar system takes a lot of the white knuckle out of it.
Don Evans
>In my opinion yes for two reasons.
1. I will set mine for 1/2" when beginning and can really hog some wood without worrying if I'm getting close. Point here is I don't need to readjust it for the curve part at that setting.
Basically, you'll need to make at least 3 adjustments with most turnings when doing the final thickness. It's a matter of experience like with most tools.
2. Due to artiritis a boring bar is a must have now if I want to do hollow forms any bigger than ornaments.
I got the Jamieson couple of years ago and wouldn't give it up without a fight.
Don
your welcome to come over and try mine
Re: use of a laser for hollowing *LINK*
Fred Holder
>The article that introduces the laser for hollowing can be found at my web site. Shortly after I published that article, many hollow form turners adopted it and found it to be a great convenience.
I own several different staballized hollowing rigs and have laser attachments for all of them. They have saved me from turning through the side of many hollow forms.
The Lyle Jamieson system fitted with the new Hunter Carbide tool does wonders in hollowing. Add the laser attachment and it is the best available, in my opinion.
More Woodturning Website
Pete in Holland, MI
>I will be building a hollow form turning mechanism soon and a laser will be a part of it. Having a laser on your tool lets you know where you are in "real time", verses "where you think you are and will find out when you stop and check".
Pete
Lyle Jamieson
>Joe, this is the answer that will be printed in Fred Holders More Woodturning Publication.
Answer for Joe,
Thanks for the question Joe. This is right up my alley. I hope this does not sound like a commercial. There are many home built laser systems being used out there as well as mine, so lets talk about the concept.
I am sure some of you have heard me say this before but it is worth repeating. If I were this 20 something year old stud and didn�t care about beating my body up with hand held blind hollowing tools I would still have a supported hollowing system just because of the laser. And I can not put a laser on a hand held tool because there are too many variables. The laser can open up possibilities that traditional measuring devices can not do. They are accurate, I can do a goblet as thin as a fingernail. I am in complete control even as a beginner to never work on a vessel for hours only to go through the side and make a funnel, never again. I can see the shape and depth of the inside bottom of hollow forms through the waste block under the faceplate (no traditional measuring methods can do that!!). Its fun, its easy, its fast�much faster.
As with any measuring you have to measure 90 degrees to the wall so the laser has to be set periodically to follow the shape, but once it is set you are home free to hollow that stage of your vessel to a uniform wall thickness. My system stays in adjustment and only needs to be checked when you move to a different stage of your vessel.
Yes, this laser wave was started by Dave Thompson showing how to hold a laser on a boring bar. I recall speaking with Dave and his reply to my marketing question was that he just wanted turners to be able to have more fun turning. Thank you Dave Thompson!! I have tweaked Dave�s original methods for measuring but it is the way people are turning now. Thousands of turners are using a laser assist for hollowing. All the set up and use techniques are in my Hollow Forms The Easy Way DVD. Not too many tools actually make your turning funner, faster, better, and easier as the laser does. Lyle Jamieson
Ed Heuslein
>Howdy Lyle: Very well stated. I appreciate your infrequent but timely and intellingent remarks. Please keep them coming. And, for what it's worth, I agree with you. - Ed in East Texas.
