John Lucas - bending HSS rod
>John,
As per hour discussion following Drozda's demo, I heated a 1/4" HSS rod to cherry red with a Mapp gas torch and bent the end over nicely. (It certainly didn't act anything like mild steel.) I then grabbed the bent end in the vise and heated a bit further back to bend the other way to make the crook. The rod snapped in the middle of the first bend.
I don't know whether:
a) I put too much pressure on the rod before it was hot enough to bend properly,
b) if heating and cooling the first bend caused hardening which would require tempering (did you say the critical temperature should be much higher than cherry red?),
or c) whether several heating and cooling cycles did something to weaken the rod.
I will try again tomorrow. If it breaks again, I'll break out the oxy-acetylene torch and try a little more heat.
