ADVERTISE HERE - FREE TRIAL
Renaissance wax question ??
Ed Moore in SW Virginia
>I found an older can of Renaissance wax that is about half full of dried up wax. I would like to rejuvenate this wax, so my question is, what solvent should I add to soften, but not destroy, the caked wax?
TIA,
Ed
Re: Renaissance wax question ??
Carole Valentine
>Ed, the MSDS says white spirits (Stoddards solvent). I am not sure, but I think that is Naptha. Maybe some chemist will chime in. JL??? Renaissance has a really long shelf life if it is closed tightly.
>Thank you, Carole. I bought a lot of Renaissance Wax in the 70's and I think these two cans are the last of it. One can is usable and the other is caked. I will locate some naptha and try it. It's worth a try. The secret may be to not use too much solvent as I start the effort.
Ed
Carole Valentine
>Better check and be sure naptha=white spirits=Stoddards Solvent. I don't know if there is a difference. I know Ren. Wax is not highly flammable, but I think Naptha is.
John Scheideman
>Ed,
Please post your solution when you figure it out. I, too, have some Ren. wax that has caked and I'd like to use it. Thanks!
John
flammable?
>From various sources (which appear consistent): There are at least three different types of "white spirits", or stoddard solvents, each with different properties and flash points. Originally developed for the dry cleaning industry after a many explosions and fires, stoddard solvents are derived from parafin and are less volatile and less toxic than many other petroleum-based solvents. Used many paints and varnishes and to clean brushes. Also called "mineral spirits" by several sources.
Might break off a chunk and see if it dissolves/softens in mineral spirits.
Russ Fairfield
>To answer both Ed and Carole;
Stoddards Solvent is what we can buy as Unscented Mineral Spirits, which is regular Mineral Spirits that has been more highly refined.
Turpentine can be used as a solvent for all waxes, and that includes Renaissance. By Turpentine, I am referring to the real Gum Spirits, and not the substitutes.
Thanks, Russ. I was hoping ...
>that you would chime in here. I'm off to Lowes to get some unscented Mineral Spirits. I think that I have that turpentine. Since Renaissance wax has a low scent as compared to some, I'll try the MS first.
Ed
Interesting discussion
Mike Brazeau
>Was using LV Conservator's wax recently and noticed how quickly the solvent phase evaporated when applying. Smell seems very much like Hexane which I often used many years ago, in my other life, as a lab solvent when I sold gas chromatography instruments. Turns out hexane is a major component of stoddard solvent. In Canada we don't commonly see mineral spirits but get varsol. It seems to have more slightly heavier hydrocarbons.
>Turpentine can be used to dissolve waxes. It is not quite the same as mineral spirits though.
Turpentine is distilled from pine and other tree resins. As such it has a lot of terpenes (basic unit C5H8). As such, turpentine usually has more double bonds than mineral spirits (C10H16).
Mineral spirits contain much more of a mix of molecules and isomers than turpentine. Typically the molecular weight range is much greater (C8 to C15). Mineral spirits may also contain a number of cyclic and aromatic molecules that are not typically found in turpentine.
Personally, I find that turpentine has a much more pleasant odor and is easier to work with. Unfortunately it is more expensive.
read that turpentine has a higher health risk
Re: Thanks, Russ. I was hoping ...
Michael Stafford
>It is my understanding that Renaissance wax and most other microcrystalline waxes are pure petroleum deriviatives and thus the mineral spirits would be the solvent of choice. If I am wrong and it would not be the first time, please let me know because my statement is based upon a conversation with a gentleman who worked in the refining industry for years and gave me that information.
Russ Fairfield
>Yes, Renaissance is made with a petroleum solvent. That's why it smells like kerosene. But that in no way prevents using Turpentine as a thinner. Turpentine and Mineral Spirits are compatible.
Re: Interesting discussion
Jim Shaver - Oakville, Ont
>Hi Mike,
I often sub mineral spirits with Turpentine, as Russ mentioned the authentic source. I use the Conservators Wx a lot, and with my experience there is no difference between it and Ren wax, others disagree.
take care,
Jim
Russ is correct! No surprise, but I ...
>got some Crown "Low Scent Mineral Spirits" and added some to the can after I ran a sample test. It still needs some blending, but the consistency is approaching the original. As you would suspect, I added too much, so it is a little less firm than the original, but it is certainly usable as is.
Thank you Russ, and the others who contributed. I forgot to get some naphtha, so I didn't try Carole's original idea, but I wish that I had.
Ed
