Have a question? Ask Woody!
Home Made Turning Tool
Tomm
>I made a turning tool from a square shaft screwdriver. I do not have the handle on the tool so it would be easy to heat treat if needed. Would heat treating be necessary? I ruined an inexpensive hacksaw blade trying to cut through the blade so I think the steel is harder than cold rolled material. Thanks for your thoughts.
Re: Home Made Turning Tool
Tomm
>Sorry for the mistake spelling homemade. It really shows when it is in a title.
Re: Homemade Turning Tool
Tomm
Paul Waddle
>Hey Tom,we all make scraping tools from screwdrivers... I would take a little more time and epoxy a metal turning bit into to socket screw driver. No criticism is implied,you are probably more adept at turning then I am.pw
Re:If it seems to be that hard, I wouldn't .....
JamieD
>... try to improve it and possibly make it worse rather than better. Screwdriver steel comes in every degree of hardness, and the tools we make from them seem to work pretty well as they are without further modifications in steel quality.
>You don't need to go through the heat treating. Just use it and resharpen often. It didn't cost much. You probably don't know what kind of metal it is so heat treating would be guesswork anyway. I've heat treated screwdrivers and think they were better but I really didn't have a good basis for that assumption.
