set the tree on fire
>A new one on me: I set the outside of a tree on fire with the chainsaw.
I had a 26" standing dead red oak come down across one of my trails a month or so ago. The bark and much of the sapwood was long gone and the tree turned out to be quite dry inside instead of the usual soaking wet.
Cutting with the top of a 16" bar from below in a buried cut, I saw a little smoke, not unusual, but pulled the saw out when I saw some sparks. Evidently the friction of the chain against the dry wood ignited fine bits of sawdust which were carried around the sprocket and sprayed on the outside of the tree which was also dry. I had to put the fire out with my boot!
Anyone ever hear of such a thing?
Re: set the tree on fire
Ken
>Gotta say that after over 40 yrs of using chainsaws,this is a first,sure not doubting you my friend,but I have never even heard of that.Goes to show that we never stop learning.Gotta remmember that as I cut up a lot of dead wood when I am up at our place in NC.
GalenV
>Cut a LOT of railroad ties for landscapeing and made a lot of smoke and sparks but guess you beat me out with actual fire from a chain saw.
Good thing I hear Smokey the Bear is retired or you might have been in big trouble.
Galen
Dick Hines
Dick Hines
>Sounds like you need to put a file on that chain, John
What dat noise????
Michael Stafford
>You were running the engine as you cut, right?
Sliding it back and forth would certainly generate a considerable amount of friction.....;-)
John Jordan
>I've seen smoke from a couple of student's bowls-no fire though.
John
sharp chain
>Dick,
The chain was sharp. I didn't mention that after that first cut I made a half-dozen more cuts with the same chain to make sections small enough to roll off the trail.
I think the friction was not from the teeth but the chain against the bar. Since it was basically a plunge cut, some fine (dry) sawdust from deep in the log must have wedged under the chain in the groove at the tip and the increased friction ignited that and the chain carried the embers back. A wimpy saw might have bogged down but this was my favorite little Stihl.
But I will sharpen before I go to the next tree. Just down that hill are a big red oak and a white oak on the ground, soon to feed the sawmill. They are both nicely green. This experience did encourage me to strap a fire extinguisher on my little Cub Cadet truck.
Brad Vietje
Re: sharp chain
Brad Vietje
>JKJ,
Great story -- nope, never did that! Would make a good video clip.
Be sure to check the wear on the bar, and make sure your oiler is not plugged. If there's a burr or little ridge built up on the edge of the bar itself, you'll need to file it flat to make sure the chain doesn't have too much "flop" or play. You might need a new bar if there's been a lot of wear on it.
Safe spinning (and sawing!),
Brad Vietje
Newbury, VT
bar wear
>Thanks - the oiler appears to be fine. I check for appropriate oil levels at every filling and I've filled twice since then.
I turn the bar regularly to equalize wear and after years I finally bought the tools to rework worn groves in old bars. This has greatly increased the bar life and reduces chain wear as well. The adjustment tool is so, SO much better than my old way when the chain got loose in the bar - hammer and anvil!
I really think this was simply the combination of a dry interior, a plunge cut on a large diameter, and perhaps a little play at the tip as the chain heated which allowed fine sawdust to get under the chain. I was being pretty aggressive with the saw, cutting up from underneath since the log was suspended. The tree itself was standing dead and the bark gone when we moved here in '03. The guy we bought it from lived here since the '80s and never went into the woods so who knows how long it's been dead.
Re:JohnK- how can a worn bar be ......
Jamie D
>....repaired other than filing the top surfaces flat? You mentioned a tool to repair worn grooves?
chainsaw bar maintanence *LINK*
>- Carefully file the top surface flat and knock off any burrs. Do not round the edges. Bailey's sells a "universal edge sharpener" which works great for this.
- Clean the groove.
- Check the chain in the gap, if too much play from wear, close the gap with a rail closer tool. This prevents the chain from tilting in the gap which can accelerate wear. Also, if the chain tilts over in a worn rail, the saw cuts like crap. (Can I say crap here?)
- Flip the bar every several sharpenings to promote even wear on top and bottom.
- Clean out the oil holes in the bar often.
- Check for drive sprocket wear.
- I lubricate the front sprocket since the bar oil may not reach there. I also lubricate the bar rail directly before reinstalling the chain.
Also, no extra charge: file the depth gauges on the chain properly. If you don't sharpen the chain yourself and the shop gives you a blank look when you ask about this, maintain a grip on your chain and walk slowly backwards until you are clear and run to your car.
rail adjuster
Re: Well I'll be......, never heard of a gadget ..
Jamie D
>...called a rail closer before!
Brad Vietje
Brad Vietje
>Cool!
I didn't know about the rail closer tool, but I know many people use filing tools for tuning ski edges to dress chainsaw bars -- at least here in Ski Country...
Safe spinning,
Brad Vietje
Newbury, VT
Re: set the tree on fire *LINK*
Wilford Bickel
>John,
Have you checked the spark arrester in the muffler - this is the cause of lots of fires from chain saws. Some states have very strict laws about the spark arrester system. It should be a form of screen inside the muffler - usually the heat has welded everything up so the only way to fix it is to replace the whole muffler system.
Wilford
Bailey link to mufflers with spark arrester
tree as tinder
>Wilford,
Thanks for the advice. I saw no sparks from the muffler.
When I first noticed the sparks, I saw a stream of tiny embers being carried along the lower part of the chain into and around the drive sprocket and being blown out of the upper part of the chain guard cover directly onto the dry, barkless, crumbling surface of the tree - perfect tinder! (As mentioned, I was cutting with the upper part of the bar with the lower bar and chain free in the kerf.)
